Old 03-31-2006, 10:51 AM   #1
phillbus914's Avatar
Paint question
The weather here in Michigan is finally warm enough to paint... although probably not for long. I went to Menards yesterday & bought some black rustoloum primer, but I can't find the paint color I want in rustoloum. I've started cleaning/masking/primering the bus already.
Click here for photos
I'm looking for a dark metallic blue, so I went to a few automotive paint shops here in town today but everything they carry runs about 85-120/gallon plus the harderner & reducers. my quotes were 500-600 for everything. I'm looking to spend a lot less than that cause I'm a cheap basterd.
My question is; has anyone used metallic paint on their skoolie? If so how much did it cost? And where is the best place to shop for it also what is the best (cheapest) brand to look for?
My Old Bus :(
Old 03-31-2006, 11:46 AM   #2
Steve's Avatar
How are you applying the primer?
Old 03-31-2006, 12:15 PM   #3
trentet's Avatar
Engine: INternational DTA 360
$500 to $600 sounds about right for automotive grade paint
if you want to go the farm equipment paint route you could save a few hundred but you are limited in colors. metalics are almost excusively automotive as far as I have seen but good luck, I calculated $800 for my shorty dognose here in California, but I think I am paying a premium for California environmental restrictions.
"Beer speaks people mumble" (lagunitas beer bottle)
trentet is offline   Reply With Quote
Old 03-31-2006, 12:22 PM   #4
I am lightly sanding the yellow paint
Then washing with soap & water
Then, wipeing it with asatone to clean it
Then masking
Then spraying it with a paint sprayer ran off a 30 gallon air compressor.
My Old Bus :(
Old 03-31-2006, 12:42 PM   #5
KevinCoughlin's Avatar
Year: 1983
Chassis: International S1800
Engine: SV396 V-8, International
Send a message via Yahoo to KevinCoughlin
You can ADD metallic highlights to your paint the same way the auto guys do it. Buy pearl and mix it in. If you can't get the look you want (rustoleum might be too "thick" to let it show nicely - I'll have to try it) then shoot the rustoleum, and overlay a clear coat with the pearl in it. A gallon of House of Kolor clear coat with hardener is about 150 from autobodysupply.net - and a 6 ounce of metallic flake runs from 35 to 55 bucks. Now that I think about it, I may try some of that on my next iteration. Right now I've just shot with Sherwyn Williams DTM - like a rustoleum - with water cleanup convenience. About 2 gallons covered the whole bus with one good coat. I would have done another, but I needed to finish and get back to other projects at home before getting my wife REAL mad *grin*.
Check out the Millenium Phoenix
<www>
KevinCoughlin is offline   Reply With Quote
Old 04-01-2006, 12:08 AM   #6
I've seen goof paint in Home Depo but its usually only 1 gallon of each. I'm thinking I'm going to need 1 or 2 gallons of blue & 1 or 2 gallons of white.
I came up with a "new" idea for the paint job. Dark metallic blue on the sides but white on the roof (so I don’t cook in the summer) for the transition I'm thinkin blue waves against a white background above the windows. Also I'm thinking of a white front with white paint splashing back to the first set of side windows (just behind the sliding door) sort of like flames but more of a splash look.
I went to Lowes tonight to see what they had & the guy said they sell gold flake that you can mix in but if you mix it in oil based paint it'd dissolve. I guess I need oil paint since it’s going to be outside exposed to the elements. Is this correct? Oh yeah did I mention I know nothing about paint?
My Old Bus :(
Old 04-01-2006, 12:15 AM   #7
Year: 1983
The metallic stuff is sometimes actually mylar - and the solvents in oil based paint might eat it. But you can get water thinned/water cleanup exterior paint. I did my bus with it and it was nice cleaning the gun with soap and water. While I would have LIKED to be able to put hardeners and solvents to speed the drying time.... the stuff I got was free. Ask me next year about durability after I've had a chance to let it weather *grin*.
<www>
Old 04-01-2006, 01:05 AM   #8
lapeer20m's Avatar
I am not a paint expert, but i'd stay away from any paint that cleans up easily with water. Just doesn't seem like it would have the durability of a good oil based paint.
If you can wash the paint off your hands when you're finished something must be wrong.
Old 04-01-2006, 03:09 AM   #9
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
Send a message via MSN to Roasting8 Send a message via Yahoo to Roasting8
I don't know; I had an uncle that painted his Dodge Colt with left over Exterior Grade Latex (same color as the house) and it has lasted him about 4 years+ (he parked it in front of the house and still hasn't found it ).
Roasting8 is offline   Reply With Quote
Old 04-01-2006, 05:33 PM   #10
what do you guys think about this?
http://cgi.ebay.com/ebaymotors/AUTO-PAI ... 0352QQrdZ1
I was quoted $135.75/gallon of metallic blue paint from finishmaster this would be about $50.00 shipped
My Old Bus :(
Paint ElliottExpedition Conversion General Discussions 6 05-30-2014 12:20 AM
Paint sprayer question Diesel Dan Conversion General Discussions 5 11-21-2009 07:07 PM
General Paint Question (I have used search) kamoo Short-Bus Conversion Projects 2 08-25-2009 05:45 PM
Question about Aluminum paint vs. GM truck pewter vs GREY lapeer20m Conversion General Discussions 1 03-17-2009 10:09 AM
HELP with paint lapeer20m Conversion General Discussions 4 07-04-2008 08:53 PM
