Old 02-24-2010, 08:04 PM   #11
lornaschinske's Avatar
Rated Cap: 89
Re: Paint Questions
http://rolledon.forummotion.com/
Fulltime since 2006
Old 02-25-2010, 09:12 PM   #12
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
Re: Paint Questions
My paint scheme requires me to paint all of the aluminum window trim parts black. I did a test on one window using Tremclad (Rustoleum) spray paint. That stuff goes on too thick and stays soft for too long. I would have to keep the windows apart for a month before I could put it back together without the risk of getting the windows stuck. I want to be able to open them up again after I paint them. A simple satin black spray paint would be great, but it needs to dry fast and go on thin. I got a can of Krylon indoor/outdoor spray paint that I will try tomorrow. Has anyone else ever painted the window frame trim and what type of paint did you use?
Old 02-26-2010, 08:00 AM   #13
Year: 93
Chassis: ?
Re: Paint Questions
Anyone consider Valspar from Tractor supply? It seems better than Rustoleum if used with a hardener.
swhite832 is offline   Reply With Quote
Old 02-26-2010, 04:30 PM   #14
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Rated Cap: 48
Re: Paint Questions
Krylon Indoor/Outdoor paint = Looks great, dries fast, easy to use, doesn't stick to aluminum very well.
I think I am going to have to use an etching primer to prep the surface of the aluminum to hold paint, then I think the Krylon will work well, as long as it doesn't react with the primer. Time to go to the auto body shop to see what they have for self-etching primer, and who knows, maybe I will find a better trim paint. It's just too bad things cost at least double at an auto body shop compared to hardware stores. I guess you get what you pay for in the end!
Old 02-26-2010, 07:01 PM   #15
Year: 93
Chassis: ?
Re: Paint Questions
Valspar....bought "Best Paint Sold". It is a farm implement paint. Anyone have any experience with it?
Old 02-26-2010, 07:12 PM   #16
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Rated Cap: 48
Re: Paint Questions
In an attempt to find some compatible self-etching primer to use for my window trim, the body shop supply store recommended a product designed specifically for trim. It is made by Pro-Form, an auto paint company. It is self-etching, works on plastic, metal, aluminum, galvanized metal, and can be used alone or as a primer. It is satin black, so it matches most automotive trim and wont fade away. Best of all, it was about the same price as the other types of paint that I have been trying. It is Pro-Form PF543.
New Bus owner Questions about tractor paint RV style bus Deshet Conversion General Discussions 16 06-24-2014 09:30 PM
HELP with paint lapeer20m Conversion General Discussions 4 07-04-2008 08:53 PM
Paint...and more paint...and more paint... skooliedave Conversion General Discussions 13 02-02-2008 03:22 PM
can transit bus people post too? jakes and paint questions kbunnystarr Conversion General Discussions 0 11-07-2006 01:52 PM
When to paint andybus9 Conversion Tutorials and How-to's 16 11-30-2005 08:24 PM
