Old 11-15-2009, 11:26 PM   #1
bikeforthelight's Avatar
Year: 85
Engine: Gas
Re: Paint Thread (especially Rustoleum users)
Well Smitty, I havent painted Gracey yet, but I think I am gonna spray auto paint on her. I am leaning towards nason 2k urethane. Its a super strong/hard finish that you can clear if you want, but you dont need to. Its made to have a gloss to the paint itself. Costs a bit more, but I think I can do the whole bus for about $300. I am picking up a spray gun to use with my compressor for about $40. Thats the plan at least. I will be spraying it in a big field that is wide open. I may get some bugs and dirt, but the urethane is made to be wet sanded and buffed out for any runs and bugs and still look great. Its a dupont product I believe, and have heard nothing but great things. Its the same stuff they are using for tractor equipment nowadays. Just what I plan on doing. Who knows tho, I may end up using a roller too. Best made plans....
Im Johnny. I Bike For The Light. I love missions. I think students rock. I make my mark.
https://www.bikeforthelight.com
bikeforthelight is offline   Reply With Quote
Old 11-16-2009, 03:48 PM   #2
Ob1
Year: 1963
Coachwork: Grumman
Chassis: Chevrolet
Engine: Chevy 292 I-6
I'm gonna paint mine with base/clear. Being a car painter, why not?
Problem is, so...so many colors to choose from!
But, I think that for acrylic enamel with hardener, Tractor Supply may be the best deal out there.
Ob1 is offline   Reply With Quote
Old 11-16-2009, 06:45 PM   #3
Chassis: Ford B700
Engine: 5.9L Cummins
1- Did you consider and/or use Rustoleum to paint your bus?
I did originally but the guy who painted my bus said that it wouldnt hold a shine for very long and would have to repaint it pretty quickly. I bought XO Rust but he made me return it, said it takes too long to dry and he has had problems with the surface cracking. So I used Richards equiv of rustoleum. It took forever to harden, scratches fairly easy and doesnt have a really nice gloss to it although it did at first. He uses rustoleum alot for trailers and for painting the frame rails etc on trucks.
2- If you considered it, but didn't use it....why not? What did you use?
Used Nason 2k
(feel free to add anything else you like)
Following questions strictly for Rustoleum paint:
3- How did you apply it?
Sprayed on (interior Rustoleum equiv and the Nason 2K exterior)
4- How long ago did you paint your bus?
3-4 months?
5- How do you feel it's held-up, including any problems like flaking, fading, chipping, staining, chaulking, etc. Please list any problems you had I didn't mention.
Really well, with the Nason 2k - has taken a few hits here and there with no damage. Its on the painters pickup and it still looks good after 2 years with the exception of the overspray that has landed on it. With the air dry (rustoleum) it scratched easily and has lost quite a bit of its gloss without even beig exposed to the elements.
6- Would you use it again for an overall paint? Why or why not?
Yes without a doubt with the Urethane Nason 2k. Wouldnt use clear since it was sprayed outside, the clear magnifies every little spec of dirt and can end up looking pretty bad. With the single stage, the contaminates are hidden in the paint. If I had a booth, Id use a base/clear. I dont think I would use the Rustoleum or equiv again on anything but the frame since it didnt hold a shine very well. Its a fairly durable paint when dry but just doesnt look that good. I had an old truck painted with it, same deal.
kamoo is offline   Reply With Quote
Old 11-16-2009, 06:59 PM   #4
reprobate's Avatar
We used Kelly Moore brand industrial metal paint and then an auto clearcoat. Still holding up nicely.
reprobate is offline   Reply With Quote
Old 11-16-2009, 07:16 PM   #5
thesaltydog24's Avatar
When the time comes for me. I'll be spraying it with automotive paint. My father is a Chemist for a major paint company so I got the hook up on free paint, primer, bondo, and clear coatings and If my timing is right I could just get a good hook up on sheet metal they have used for test sprays. If I didn't have the hookup then I would probably use Rustoleum.
Chris
thesaltydog24 is offline   Reply With Quote
Old 11-16-2009, 09:37 PM   #6
GoneCamping's Avatar
Yes I considered it, and that is what I used...
N/A
First of all, I had to mix it down a little according to instructions on the side of the can, the mix-down was 15% Acetone to thin it a little... I then used a HPLV sprayer and did the paint job outdoors. It came out very well, only found 1 bug stuck to it.
I think it was 3+ years ago...
Rustoleum is great stuff if you want something that will stick to anything. So with that in mind I did NOT do any sanding on my bus, I simply wiped it down with Acetone to remove any prior (yellow) oxidation, dirt-grime, etc... I had a couple of spots where it did chip with contact by a tool or hard object. I also had some flake off where the Roof A/C run-off had dripped all summer long. Though it seemed like it would loose it's shine, all I had to do was wash it and it would shine again. I did notice that in the last couple of months the front valence over the drivers windshield was oxidizing or chalking, and some of the oxidization would run down the windshield and leave white streaks on the glass...wiped up easily though.
If I was willing to sand the bus first, I'd use an automotive paint. But that is a lot of surface to try and sand. Not sure I'd use it again or not, I could see it developing some issues...but it otherwise worked well enough.
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 11-16-2009, 10:52 PM   #7
sportyrick's Avatar
Chassis: F33695
1) I used a modified enamel (implement)that Car Quest sells for $35 a gallon. It pretty much is rustoleum in my opinion.
2) was reccomended to me by the paint guy, said a lot of people use it to paint equipment that is exposed to the weather.
3) sprayed over a regular automotive primer after sanding
4) 2006
5) only problem I can see is it's slow drying and scratches easy until the sun bakes it for a few days or weeks (no clear
coat). Still shines good, no fading I can see, no chalking, looks great. Limited amount of colors though. Look at my air dam picture, how does it look?
WARNING TO ALL PAINTERS!!! Urethane paints contain cyanide, you must have a fresh air helmet to keep you away from any and all fumes, filter masks won't cut it.
sportyrick
Old 11-19-2009, 06:28 PM   #8
Chassis: Ford B700
I fixed my post.
rustoleum paint where to get? gbstewart Conversion General Discussions 10 06-29-2010 07:35 AM
The $50 paint job - Rustoleum dentedvw Conversion General Discussions 10 03-19-2010 05:59 AM
Any Sprint users?? Redbear Everything Else | General Skoolie Discussions 0 12-02-2009 09:09 PM
Rustoleum Hammered paint! KC10Chief Conversion General Discussions 9 07-15-2007 11:17 AM
100+ Users Steve Forum Admin | Account Help | Suggestion Box 1 06-17-2004 12:43 AM
