Old 06-29-2015, 02:40 PM   #1
Painting a bus - what kind of paint and how to sand effectively?
I've seen a lot of different opinions on painting buses here, so I wanted to lay out a scenario and see what you all recommend:
Let's say I'm painting a 40 ft. Bluebird FE bus. Once I've removed all the reflective adhesive, reflectors, etc., I need to sand the bus, correct?
I've heard that 320 grit sandpaper is best, but should I use an orbital or belt sander to do the "bulk" areas? Or just sand by hand only?
I would be using Rust-Oleum or similar oil-based enamel paint, is that a good choice? I read others recommending acrylic enamels, is that a better choice or does it really matter?
I don't plan on priming, but once I get everything lightly sanded and cleaned with mineral spirits, I'm going to paint the roof white, then paint the body gray. It looks like a sprayer is the best option (once the paint is appropriately thinned). Is one coat realistic or should I plan on multiple coats?
Should I spray the whole body (except the roof) gray, then paint over the gray point with accent colors (for example, black bumpers, red trim might be likely) using hand rollers/brushes? I assume I would need to wait for the gray coat to dry before painting the detail areas (assuming I want to mask those areas before painting and not try to freehand).
I'll be happy to clarify any of this, I'd just like to get some more direct advice; I don't want to have to do this twice! Thanks.
-Dan
dbsoundman is offline   Reply With Quote
Old 06-29-2015, 02:55 PM   #2
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
I've just been using ACE Hardware rattle cans right over the yellow, with no prep work other than reflective tape and letter removal and washing down.
Captain Obvious on deviantArt
Old 06-29-2015, 03:21 PM   #3
Wouldn't that take a TON of rattle cans? I feel like a paint sprayer would be more efficient but I'm interested to hear what you think.
Old 06-29-2015, 05:09 PM   #4
If you have access to a compressor, a little HVLP sprayer can be found cheaply and used with ease. With that you can get Rustoleum by the gallon or quart as needed which can yield a really good looking and pretty durable paint job. Given the price of rattle cans, I'd keep them back for touch up. There are a LOT of square feet on the average bus...more than I would want get after with cans. But one of the big advantages of going with Rustoleum is that you can find touch up paint just about anywhere...rattle can or otherwise.
Automotive paints are far superior if you want a high fashion finish, but personally, I don't plan on spending the kind of dough those paint jobs cost.
Old 06-29-2015, 05:18 PM   #5
Thanks for the advice! I definitely thought about automotive paint, but considering the fact that most skoolies and such I've seen (or "party buses") have some sort of uneven-looking flat paint on them, I think Rust-Oleum should look pretty sharp.
-Dan
Old 06-29-2015, 06:16 PM   #6
Get a compressor and a paint gun.
Even a cheapo paint gun can do a pretty nice job compared to rattle cans.
I was using cans and switched halfway through the project.
If done right, Rustoleum can look REALLY good. I like that its cheap and easily available.
Paint Your Car With Rustoleum
Old 06-29-2015, 08:10 PM   #7
Watch out for cleaning up with mineral spirits. Mineral spirits leave a slight oil film behind which will cause "fish eyes" in almost every top coat finish. If you use mineral spirits be sure to wash off the film with a strong kitchen dish detergent and then rinse very well with water. Jack
Old 06-29-2015, 08:53 PM   #8
whole lotta painting here.....
3 pages worth
http://www.skoolie.net/forums/members/157-albums96.html
Old 06-29-2015, 10:04 PM   #9
opus's Avatar
Chassis: All-American R/E
If you use Ace or Rustoleum, be prepared for it to go flat after a couple years. That is unless you clear coat, etc. If I had it to do over again, I would have left mine yellow or just hit it with some rattle cans and called it good.
I didnt do a lot of prep work so I am not unhappy. Its lasted 5 yrs I think. Now, I'd like to blow it all off but I dont think I can do that without a lot of work....yet.
Old 06-29-2015, 10:41 PM   #10
We can't legally leave it yellow here in NY. I'm planning on using Rust-oleum over primer. Not sure if I'll clear coat over that or spend a year waxing it.
steveoutdoorrec is offline   Reply With Quote
