05-25-2019, 05:19 PM
Year: 1994
Coachwork: N/A
Chassis: Chevy C30
Engine: 7.4L gas
Rated Cap: 14,000lbs
Painting help
Hi Guys!
I'm hoping to get my bus painted this weekend (if the Oregon weather will let me) and I've got a couple of questions I hope someone can help with.
Firstly, does anyone know if it's possible to stand on the hood of a CE 2000 international without hurting it? And if not, how did you all reach the portion of the bus over the hood? Did you lie on the roof?
Secondly, any tips for getting the sticky residue left by huge stickers on the back door? So far I've tried Goof Off, TSP and wet-dry sandpaper, and it's making a bit of a difference in it but not much.
thanks!
05-25-2019, 05:22 PM
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
Originally Posted by ladybird_bus
Hi Guys!
thanks!
some regular paint thinner is what l use to get that sticky stuff off - it;s still a PITA, but it works
05-25-2019, 05:59 PM
Coachwork: Prevost
Chassis: H3-45
Engine: Detroit DDEC III
Rated Cap: A LOT
I've assembled a bunch of sawhorses that I saw on YouTube. They're lightweight, very strong and cheap. With them I've been able to line them up along the side of my Prevost and put down some plywood on them. This has been a real help getting walls and furniture in and out of my bus. But I mention this because it didn't take long until I realized that these sawhorses were going to help me paint my bus when it came time for that.
Here are the ones that I built. Hope this helps:
Isn't it amazing!! The person that never has the fortitude to pursue his own dreams, will be the first to try and discourage you from pursuing yours.
05-27-2019, 09:55 AM
Year: 1994
Coachwork: N/A
Chassis: Chevy C30
Engine: 7.4L gas
Thanks for the replies!
The answer, in case anyone else is looking some time is: yes you can, if you stand right next to the windscreen on the frame.
05-27-2019, 11:00 AM
ugh! thats how the cowling got damage in my superior.. flexes the seal at the windshield and makes the cowl to body leak... be careful with that... 2 step ladders and some sturdy planks are are what i do...
05-27-2019, 11:11 AM
Your pic brings back not so fond memories of painting those parts. I ended up opening the hood and climbing in with the paint. Was able to find solid footing and rested the paint on top of the roof. Still have touch up to do but weather here doesn't allow that yet. Pretty solid footing standing on the old CAT.
Chassis: TC1000 HandyBus
Rated Cap: 26 foot
thanks!
https://www.ebay.com/sch/i.html?_fro...wheel&_sacat=0
05-27-2019, 02:32 PM
I've been up there. Its alright if you're careful. I know what you're talkin about though!!! Its best to not do it.
05-27-2019, 02:37 PM
https://www.homedepot.com/p/ZEP-13-o...9848/308681892
Spray this on the gunk, let it sit 10-15 minutes, then scrape it gently with a painter's tool like this: https://www.homedepot.com/p/Husky-14...-G14/202038673
You may have to apply the zep a second time, but usually you can just wipe the gunk off with paper towel (it has the consistency and feel of rubber cement at this point) and then wash with soap and water.
05-27-2019, 10:08 PM
Chassis: Thomas
Engine: CAT 3126
Rubber wheel will take off most things. Worked well for my reflection strips and lettering. Kind of expensive but did the job.
05-27-2019, 10:46 PM
Rated Cap: 26 foot
At NAPA they are $40-$50. on ebay (see link above) they are less than $10. Won't ruin your paint.
05-27-2019, 11:06 PM
I bought 2 of those eBay ones for $8ea. Used it on the side lettering. I was not worried about saving the yellow paint, so this turned out to be the quickest way to remove the reflective stripes, doesn't hurt the metal if you use the proper pressure.
05-28-2019, 01:37 AM
Chassis: IH 3800, 8 window
Going barefoot is critical to avoid marring that fine chromium yellow finish!
05-28-2019, 01:56 AM
Yup, I always try to go barefooted!
06-13-2019, 08:24 AM
Engine: 5.9
i placed step ladders on each side of bus and ran a 2 x 10 board above the hood and let board rest on the steps . make shift scaffolding
06-13-2019, 08:41 AM
My front cap is bashed. Needs lots of love so gonna have to use that method. Thanks
06-13-2019, 09:42 AM
Year: 1994
Coachwork: N/A
Chassis: Chevy C30
Engine: 7.4L gas
Thanks for all the replies!
We got it done - so grateful for the very kind friends who came over and worked hard to prep the bus! The paint turned out quite well for rollers and brushes, I think - still needs another coat and some details finished but all that old yellow is a thing of the past
