Old 05-25-2019, 05:19 PM   #1
Engine: 6L
Rated Cap: 21,000lbs
Painting help
Hi Guys!
I'm hoping to get my bus painted this weekend (if the Oregon weather will let me) and I've got a couple of questions I hope someone can help with.
Firstly, does anyone know if it's possible to stand on the hood of a CE 2000 international without hurting it? And if not, how did you all reach the portion of the bus over the hood? Did you lie on the roof?
Secondly, any tips for getting the sticky residue left by huge stickers on the back door? So far I've tried Goof Off, TSP and wet-dry sandpaper, and it's making a bit of a difference in it but not much.
thanks!
ladybird_bus is offline   Reply With Quote
Old 05-25-2019, 05:22 PM   #2
Sleddgracer's Avatar
Chassis: still looking for my bus
Originally Posted by ladybird_bus View Post
Hi Guys!
thanks!
some regular paint thinner is what l use to get that sticky stuff off - it;s still a PITA, but it works
Sleddgracer is online now   Reply With Quote
Old 05-25-2019, 05:59 PM   #3
WoodenYouKnowIt's Avatar
Coachwork: Prevost
Chassis: H3-45
Engine: Detroit DDEC III
Rated Cap: A LOT
I've assembled a bunch of sawhorses that I saw on YouTube. They're lightweight, very strong and cheap. With them I've been able to line them up along the side of my Prevost and put down some plywood on them. This has been a real help getting walls and furniture in and out of my bus. But I mention this because it didn't take long until I realized that these sawhorses were going to help me paint my bus when it came time for that.
Here are the ones that I built. Hope this helps:
Isn't it amazing!! The person that never has the fortitude to pursue his own dreams, will be the first to try and discourage you from pursuing yours.
WoodenYouKnowIt is offline   Reply With Quote
Old 05-27-2019, 09:55 AM   #4
Engine: 6L
Thanks for the replies!
The answer, in case anyone else is looking some time is: yes you can, if you stand right next to the windscreen on the frame.
Old 05-27-2019, 11:00 AM   #5
ugh! thats how the cowling got damage in my superior.. flexes the seal at the windshield and makes the cowl to body leak... be careful with that... 2 step ladders and some sturdy planks are are what i do...
Old 05-27-2019, 11:11 AM   #6
Your pic brings back not so fond memories of painting those parts. I ended up opening the hood and climbing in with the paint. Was able to find solid footing and rested the paint on top of the roof. Still have touch up to do but weather here doesn't allow that yet. Pretty solid footing standing on the old CAT.
Old 05-27-2019, 11:11 AM   #7
Mountain Gnome's Avatar
Chassis: TC1000 HandyBus
Rated Cap: 26 foot
thanks!
https://www.ebay.com/sch/i.html?_fro...wheel&_sacat=0
Old 05-27-2019, 02:32 PM   #8
I've been up there. Its alright if you're careful. I know what you're talkin about though!!! Its best to not do it.
Roll Your Own Build Thread
Old 05-27-2019, 02:37 PM   #9
https://www.homedepot.com/p/ZEP-13-o...9848/308681892
Spray this on the gunk, let it sit 10-15 minutes, then scrape it gently with a painter's tool like this: https://www.homedepot.com/p/Husky-14...-G14/202038673
You may have to apply the zep a second time, but usually you can just wipe the gunk off with paper towel (it has the consistency and feel of rubber cement at this point) and then wash with soap and water.
musigenesis is online now   Reply With Quote
Old 05-27-2019, 10:08 PM   #10
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
Rubber wheel will take off most things. Worked well for my reflection strips and lettering. Kind of expensive but did the job.
My Build Thread:
http://www.skoolie.net/forums/f11/4-...ner-18205.html
