Old 10-15-2019, 10:55 PM   #1
peakbus's Avatar
Chassis: Ford E450
Engine: 7.3 Diesel
Rated Cap: 25
Painting Spray-foam?
I read someone's comment in a bus post on Instagram that the person better paint/seal their spray-foam before they install the ceiling otherwise the little dust from the trimmed surfaces will forever be raining down through the cracks and crevices. I read it as 40% -"this has happened to me", mixed with 60% -fear/conspiracy. The 40% side made me wonder if painting really could prevent some fallout, or even off-gassing. Anyone heard or experienced issue?
peakbus is offline   Reply With Quote
Old 10-16-2019, 12:37 AM   #2
Sleddgracer's Avatar
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
coming from a professional painter, paint might help prevent what little insulation dust there might be - i doubt it would help with the off gassing - paint does not stop hydraulic pressure that's trying to push it off the surface - gas, air, water can all be classed the same - if I wanted to seal off spray foam I'd dilute Bond Fast glue at 2 gals of water to one gal of glue - makes an excellent sealer on a variety of surfaces including foam, stucco, and concrete and it's many times less costly than paint primer - it also works slick as a sealer when you don't want a clear coat to darken wood - the dilute Bond Fast seals the wood and prevents the clear coat from changing the colour of the wood
Old 10-16-2019, 01:14 AM   #3
I tell you what, Sleddgracer ... you are a font of valuable information and experience!
Old 10-16-2019, 05:44 AM   #4
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
Old 10-16-2019, 10:58 AM   #5
peakbus's Avatar
Chassis: Ford E450
Engine: 7.3 Diesel
Rated Cap: 25
Thanks for the good tip! If the weather hadn't turned, I might be inclined to spray a coat but I think I may forgo it now. I vacuumed the surfaces well. I might use that as a sealer on the back of my t&g ceiling material though. Is Bond Fast the typical white all-purpose glue?
Old 10-16-2019, 11:05 AM   #6
Solvent based stuff might dissolve your foam. Make sure whatever you use won’t eat it.
Old 10-16-2019, 11:11 AM   #7
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
Bond Fast IS the typical white all-purpose glue
Old 10-16-2019, 11:27 AM   #8
peakbus's Avatar
Chassis: Ford E450
Engine: 7.3 Diesel
Rated Cap: 25
Old 10-31-2019, 08:12 AM   #9
sportyrick's Avatar
Chassis: F33695
I have used spray foam to fill the rotting rocker panels on an old pick up. It keeps expanding for years, cracking my rattle can paint job and showing cracks. I would watch where you use it where it's exposed to searching eyes.
Old 11-01-2019, 10:58 PM   #10
Take a shop vac, hook the hose to the exit side, and blow all the dust off.
Iqinsanity is offline   Reply With Quote
