07-23-2015, 09:33 AM
Coachwork: Navistar
Engine: Allison
Rated Cap: 60
Painting the inside.
Hi all,
getting ready to paint the ceiling of the bus and was wondering:
1. best paint to use?
2. My bus has acoustic paneling near the front for noise reduction. can i paint over that? and if i do and alot of the holes get plugged with that be bad?
thank you
07-23-2015, 10:26 AM
If the acoustic panel is the perforated metal type...yes, plugging the holes will make it no longer acoustical.
07-23-2015, 11:26 AM
Chassis: Thomas
Engine: International Navistar DT360
Rated Cap: 60
I painted mine with a roller and it turned out awful splotchy. It's impossible to get it to cover right because even if you paint it hard enough to fill the holes it hits the insulation behind it, and the insulation doesn't always touch the back of the roof panels so that looks splotchy too. I put three coats on without filling the holes because I didn't want to hit the insulation, and there are still roller lines everywhere because parts of the little circles get paint on the inside edges of them and parts don't and there's no way to even it out. After the third coat I was just wasting paint.
I don't mind the roller marks terribly, and once everything's in the bus and especially during certain times of the day you can't really tell. That being said, if you're a perfectionist the only way to do it would be to take all the panels down and spray them. Or decide that you're ok with the original paint. Or just enjoy your roller marks.
My build thread:https://www.skoolie.net/forums/f11/build-thread-for-haulin-oats-and-goats-11237.html#post113500
A gal, a guy, three cats, two dogs, one rabbit, and one goat, traveling the country together.
07-23-2015, 11:51 AM
Coachwork: Navistar
Engine: Allison
Rated Cap: 60
I wonder if i just glued like a thin piece of something to that panel so it would be flat
07-23-2015, 01:25 PM
plugging the holes will help keep the insulation from raining down.
07-23-2015, 01:57 PM
Chassis: Thomas
Rated Cap: 60
That would be a good solution. Not sure if you'd have any condensation issues with it, though. Maybe someone has tried it?
07-24-2015, 07:24 AM
Coachwork: Navistar
Engine: Allison
Rated Cap: 60
Well not like glueing paper exaxtly lol but maybe like a plastic film or something i can stick on. I dont ill figure it out.
first i gotta clean so...fun lol
07-24-2015, 10:49 AM
Engine: 190hp 5.9 Cummins
Tear the interior out and paint the real ceiling.
No more holes and no more fiberglass insulation to rot your bus away.
07-24-2015, 01:53 PM
Coachwork: Navistar
Engine: Allison
Rated Cap: 60
were not taking panels off
lol
07-24-2015, 05:45 PM
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
And no more mold
07-25-2015, 02:49 AM
lol
Due to what?
What is your intended purpose for the bus, and how long will it need to last at such duties?
07-25-2015, 06:13 PM
Chassis: Thomas
Rated Cap: 60
Nat I know you hate rust and think that wood is the death of a bus, but if the roof doesn't leak and they're not staying in a salty winter area there's no reason to be so picky about every detail. Most of the buses on here are twenty years old or more and are holding up just fine. Sometimes it's way overkill to do all the work removing panels when they wouldn't be an issue for another ten years or more.
