Old 05-11-2019, 04:16 PM   #1
Coachwork: international
Chassis: Front engine
Engine: mechanical DT466
Rated Cap: 71+
Parts list/ Would this be called a bumper bracket?
Hi guys,
The piece attaching my bumper to the frame is badly rusted . I was told it is called a bumper bracket but have been searching that term and havenít found anything that looks like that. Iím new so I could be using the wrong terminology.. What would you call that rusted piece in the photos? Any idea where to get a new one?
Also are there resources out there that give u a piece by piece guide to each individual item (parts list) on a bus? I have a 1992 40í international FE.
File Type: jpg 82744D32-4D05-4CEB-822C-D6B69910ACF5.jpg (177.1 KB, 13 views)
File Type: jpg 085C09E0-04CE-4FCA-8FC0-E3CD9A32C1C2.jpg (230.5 KB, 14 views)
Thetireddad is offline   Reply With Quote
Old 05-11-2019, 06:24 PM   #2
Rovobay's Avatar
Rated Cap: 35
can't help you with that, but good lawd that is some serious rust! YIKES!!!!
My Build: http://www.skoolie.net/forums/f11/sk...doo-22140.html
Follow our build on Instagram at https://www.instagram.com/skoolie_doo/
Rovobay is offline   Reply With Quote
Old 05-11-2019, 06:56 PM   #3
HazMatt's Avatar
Chassis: IH 3800, 8 window
Holy moley!!! Actually, wholey moldy...
Jeezum, where'd the bus originate from? And if the bumper mount, or whatever the correct name is (if it were mine, I'd call it, "landfill"...), is that corroded, I'll have nightmares thinking of the rust in the floor and undercarriage.
Originally Posted by Thetireddad View Post
Hi guys,
If International isn't forthcoming with new ones, the only recourse left that comes to mind is a bus wrecking yard. Those babies were installed to stay put, so it'll take a bunch of penetrating oil and torque to bust 'em loose. Probably a few bust knuckles, too.
Sorry I couldn't answer your question any better. Good luck! 🤞
Old 05-11-2019, 09:46 PM   #4
Year: 1954
Coachwork: wayne
Engine: cummins 12 valve
I wonder
what the rest of that assembly looks like? is it bolted or welded to the frame.... It sure looks like some that would be time consuming to build but so big that if you had to have that shipped to you, it becomes a toss up as to whether or not. it is cheaper to buy salvage and ship or build.
I have not seen any buses around here that would be a donor.
You dont have a location posted I would offer to help build one but I dont know how far away you are.
william
Old 05-12-2019, 04:46 AM   #5
It does look like a rebuild is in order
Like others have said a bus junk yard any be the place to get the part. Do you know if it is welded to the frame, or is it bolted in? Either way, it does not preclude you from rebuilding it in place. Taking it out may be a heavy undertaking depending on the means of attachment. Then again, one swift blow may knock the whole assembly out due to the amount of rust.
I do wish you luck with replacing that!
Old 05-12-2019, 03:41 PM   #6
Rated Cap: 71+
Yes itís bolted on
No thank god itís not welded. Itís actually the only really bad spot in the bus. Under the stairs is no picnic but NOTHING like that. Any ideas what you would call that part? The frame under That bracket piece is fine.
Old 05-12-2019, 03:54 PM   #7
Sleddgracer's Avatar
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
Hi guys,
here are some bumper brackets that popped up when i googled it - maybe yours is shown here
https://www.google.com/search?q=bump...JjpgXV4eHoNGM:
bumper, parts list, rust
