Old 02-09-2010, 06:44 PM   #1
Year: 93
Chassis: ?
Re: Patching holes in the floor
You must fill each hole using metal filler and a mig welder.......
just kidding.....I'm using polyurethane of some sort.
swhite832 is offline   Reply With Quote
Old 02-09-2010, 07:20 PM   #2
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
Kidding? And here I thought I was going to have to mig weld all of those stupid seat bolt holes!!!
Of course, welding in the holes would be a more permanant way to seal up the floor, just be careful aroung the fuel tank and other 'meltable' things. I am going to polyurethane the holes in mine, I don't feel like blowing up my propane tank, or melting through a fuel line.
Old 04-21-2015, 04:41 PM   #3
thecrabshomestead's Avatar
Coachwork: Genesis International
Which brand did you end up going with, and did it work?
Mocrab
https://thecrabshomestead.wordpress.com/category/tiny-house-skoolie/
thecrabshomestead is offline   Reply With Quote
Old 04-21-2015, 04:55 PM   #4
Engine: 190hp 5.9 Cummins
Welding them shut would ruin the galvanizing on the metal floor surrounding the hole, and cause rust.
Epoxy, bondo, fiberglass, ect are all much better choices.
Old 04-21-2015, 06:51 PM   #5
I'd agree with this, don't bother welding the holes in the floor. There are all sorts of ways to do this, but welding seems like it would only open up a new can of worms.
Old 04-21-2015, 07:56 PM   #6
Hank's P-O-S's Avatar
Coachwork: Tomas
Engine: T444e
Rated Cap: 54
Woah...... People fill thoes holes?! I thought thoes were for ventalation, along with the rust!
Just kidding
I used PL construction adhesive from the bottom and expanding foam from the top ( I never removed the old wood).
Hank's P-O-S is offline   Reply With Quote
Old 04-21-2015, 09:52 PM   #7
We didn't do anything about the holes...just laid down plywood. I told Clint about all I've been reading here about the need to patch them up and he said, "If we need to I'll just crawl under the bus and caulk up the holes".
Are we on the right track about that move?
The-Breeze is offline   Reply With Quote
Old 04-22-2015, 07:27 AM   #8
Chassis: I.H.
Water is going to hit that plywood. When will you decide "if you have to"? Don't wait for the wood to tell you or the smell of mold spores. Just use caulk. I use 100 % silicon. Whatever is better than none.
Old 04-22-2015, 08:39 AM   #9
You won't be able to reach 20 % of the holes from the underside.
Old 04-22-2015, 10:07 AM   #10
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
I used 1/4" closed end blind rivets and a bunch of urethane seam sealer around them to seal mine. No problems yet!
porkchopsandwiches is offline   Reply With Quote
Floor Patching Dan-O Conversion Tutorials and How-to's 10 04-22-2015 09:47 PM
holes from bus seats thewallfan Conversion Tutorials and How-to's 8 04-21-2015 04:41 PM
Necessary to patch floor bolt holes? mtunderwood Conversion General Discussions 10 12-10-2014 12:14 PM
Sealing holes in floor firemanbud343 Conversion Tutorials and How-to's 10 09-27-2009 10:00 PM
Tore up floor - How do I seal the metal ? (Holes, etc) rail_hauler Conversion General Discussions 5 11-02-2006 08:40 AM
