Old 12-17-2015, 04:48 PM   #1
Coachwork: AmTran (International)
Chassis: Gensis
Rated Cap: 74
PEX water pipe ?
Do you recommend PEX and if so what size of pipe?
Thank you
Rodney
slager55 is offline   Reply With Quote
Old 12-17-2015, 04:50 PM   #2
yes
I used 1/2
Old 12-17-2015, 05:04 PM   #3
Chassis: Gensis
Rated Cap: 74
Pex ?
Did you use a PEX crimper? if so did your rent one or buy one?
Old 12-17-2015, 09:15 PM   #4
[QUOTE=slager55;131321]Did you use a PEX crimper? if so did your rent one or buy one?[/QUO
I used sharkbite fittings , work great, and reusable, little more money worth it.
Old 12-17-2015, 10:07 PM   #5
roach711's Avatar
Rated Cap: 19
I used 1/2" PEX also. It's quite freeze resistant (it stretches lengthwise rather than rupturing) but not very flexible. Used the clear reinforced plastic tubing where I needed to make any tight bends. Some members here have said that the clear tubing can be stretched/ruptured by high water pressures.
I got a cheap crimper at Home Depot that worked well for limited use.
Similar to this one:
SharkBite 3/8 in., 1/2 in. and 3/4 in. PEX Copper Crimp Tool with Integrated Go/No-Go Guage-23383 - The Home Depot
Old 12-17-2015, 11:41 PM   #6
I have that crimper too. I use it with a pair of vise grips and have to clamp down, re-adjust the vise grips, clamp again, etc for a few times. It's a pain compared to the $100 tool with the handles, but if you aren't doing too many crimps it's not a bad deal. The sharkbite connectors are easy, and removable, but at $6+ a pop, it adds up quickly.
Davoarts is offline   Reply With Quote
Old 12-18-2015, 11:59 AM   #7
Chassis: B3800 Short bus
I'd advise to use the pinch style stainless steel pex rings. They're incredibly easy to install and the tool is reasonably priced ($50). Here's my thread on the subject: http://www.skoolie.net/forums/f13/pe...ings-9130.html
Old 12-18-2015, 05:49 PM   #8
dredman's Avatar
I cannot imagine using anything else BUT PEX in a bus?
-much more flexible than copper
-much lighter than copper
-much cheaper than copper
-easily dismantled/re-installed with Sharkbites or nylon fittings(found at RV store)
*Sharkbites will end up costing as much as a crimper, BUT, they are easily removable with a $2 tool
My Skoolie Story on YouTube
dredman is offline   Reply With Quote
