whats the measurement?
My opening measures 24.5" by 22.5"
The standard hatch won't go in without grinding the hole wider (left to right). There are welded in supports on the sides that would have to be removed and relocated in order to allow for the 23" wide hatch.
Then the opening would heave to be made smaller (front to back) by about 1.5". If I center the hatch in my current opening the screw holes (front & back) are right on the edge of the metal. I would have to push the hatch forward then add material to the back. This would need to be done to the inside as well.
