Old 08-20-2018, 08:58 AM   #1
Engine: 466e
Rated Cap: its Yuge
Plumbing piece to reroute Coolant
Removed my rear radiator/heater and looking for a better way to clean up this hose. Should I just use a couple of elbows and a small piece of tubing to connect them? Also, i plan to keep the front heater. Do most just put ply under it, or try to raise it up and insulate like i did the rest of the floor.
Thx,
dave
MambaJack is offline   Reply With Quote
Old 08-20-2018, 09:05 AM   #2
Chassis: International FE
Rated Cap: 84 passengers
If you figure out what the ID of the hose is you can easily find a couple of elbows and some hose clamps and clean up the routing of that hose.
rensch26 is offline   Reply With Quote
Old 08-20-2018, 10:32 AM   #3
I temporarily used 1" PVC, I'd be happier with sweated copper, but this will do for now. 3 short 2-3" pieces and 2 elbows. Use the clamps off the heaters. Where are you using the heaters if you are deleting the lines?
