Old 01-08-2014, 02:05 PM   #21
wmkbailey's Avatar
Engine: 3126
Re: plumbing vent and hepvo
Originally Posted by roach711
I'm thinking the hepvo valves would work as well passing air to the tank as they do water so you'd only need a small vent at the tank. When you dump the tank the hepvos (presumably) would open up and provide basically a 1 1/4" one way vent.
I was told that the hepvo will pass air as the water is passing and does not need a vent to drain like a p-trap. It will not let air pass the other direction and keeps the "smells" out of the RV. So you would only need a vent on the tank it self, not the drain lines. This is from a Hepvo dealer. Roach is correct, if I'm to beleive the dealer.
William
https://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 01-08-2014, 09:00 PM   #22
Yup, I'd have to agree with you. I'm in the process of installing my grey tank and the 5er I tore up for parts included a spring loaded one way valve (1 1/4" D) down stream of the P-trap on the kitchen sink. This will let the grey tank drain freely. But your post reminds me that I haven"t vented that particular grey tank. I vented the black tank and the shower grey tank (which empties via a pump to the main grey tank), but completely forgot the need to vent the main 40 gal grey tank. Since drainage won't be a problem I'll just thread a 1/2" fitting into my black water vent and use PVC from the main grey tank. Talk about perfect timing--thanks.
Old 01-08-2014, 09:10 PM   #23
turf's Avatar
very cool Trunt!... there is always something eh?
hey i got my hepvos today and was test fitting them...... well 1 1/2" hepvo is a different size than 1 1/2" abs. probably the thickness of the pipe but it gonna take a couple of trips to the hardware store to make this work i think..
grrrrr
Turfmobile Build Thread
Old 01-08-2014, 09:40 PM   #24
Turf, THAT SUCKS! Good luck at the hardware store anyway!
Old 01-09-2014, 07:51 AM   #25
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Yea, I found that out too, There is a PVC fitting made to hook them together, although I'm not sure what it's called. The plumbing guy at the hardware store knew what I needed.
Old 01-09-2014, 03:15 PM   #26
roach711's Avatar
Rated Cap: 19
grrrrr
The First Law of Projects - All projects require three trips to the hardware store.
The Roach Motel
PLUMBING QUESTION, VENT RELATED bansil Plumbing, Water and Waste 30 08-31-2014 09:46 PM
P-Trap / Hepvo Waterless Valve lornaschinske Conversion General Discussions 0 04-15-2011 12:20 PM
What is this vent......... Funkpirate Conversion General Discussions 5 04-15-2010 09:46 PM
Looking for a used vent. Bus Project Conversion General Discussions 0 02-11-2010 08:25 PM
Fridge Vent! GoneCamping Conversion Tutorials and How-to's 1 09-30-2008 10:04 PM
