Old 12-31-2008, 10:26 AM   #1
Year: 1980
Engine: 366 ci gasser
Re: Plumbing/Water Tank Help!
IMO Why use a good fresh water tank with the studs for a level gauge already installed? A good greywater tank on fleabay goes for $100 shipped. And that tank you have is worth more then that! But i also understand free and having one laying around...
Your vent for the fresh water most times will be with the fill door. Turn it over little fitting vent, big one fill. So when the tank is full water comes shooting out of the hole to remind you to remove the hose...
Grey tanks can become pretty smelly so a P trap is needed!
Put it in a shopping cart and drive it into home depot and starting screwing stuff into the tank to see what fits
That will really piss off the know it all in the plumbing dept
http://www.rvsurplussalvage.com/cata...ategory_id=182 Look here for stuff...
vtwinmotors is offline   Reply With Quote
Old 01-01-2009, 01:33 AM   #2
have you thought of using the grey water tank as a flush for the black water?
cucullen is offline   Reply With Quote
Water tank guesstimate and plumbing question tomas_maly Plumbing, Water and Waste 26 11-06-2012 10:14 PM
water tank and quality of water bansil Plumbing, Water and Waste 12 03-01-2012 10:40 AM
Black water/ Gray water tank travlenhippie Plumbing, Water and Waste 3 10-21-2008 09:53 PM
plumbing fittings for water barrels? Branden Conversion General Discussions 12 08-21-2006 11:05 AM
Plumbing/Fresh water tank questions Branden Plumbing, Water and Waste 6 04-19-2005 04:30 PM
