Old 03-10-2013, 12:48 PM   #1
Coachwork: international
Chassis: thomas
Engine: 7.3 diesel
Plywood floor
Hubby was wondering if we should glue plywood to floor, then screw? Or just screw it down with no glue?
sandik is offline   Reply With Quote
Old 03-10-2013, 03:50 PM   #2
bapos's Avatar
Chassis: International Amtran RE
Engine: DT466E/MD3060
Re: Plywood floor
I would say if for some odd reason your going to take it back up I would screw only but if you want it to bond and NOT EVER come back up... then glue and screw.
Old 03-10-2013, 07:20 PM   #3
the_experience03's Avatar
Re: Plywood floor
Gluing it will make sure it stays put and that there are no squeaks. Glue also does a better job dealing with the flex than something like cheap drywall screws will. I used tek screws with glue on mine, but the screws were really just there to clamp it in place until the glue dried.
Old 03-10-2013, 08:53 PM   #4
Chassis: thomas
Engine: 7.3 diesel
Re: Plywood floor
Gotcha, thanks!
Old 03-10-2013, 09:59 PM   #5
opus's Avatar
Chassis: All-American R/E
Re: Plywood floor
Mine is floating, not attached. I have one squeak but its not because of that.
Old 10-04-2013, 01:02 AM   #6
Engine: 190hp 5.9 Cummins
Re: Plywood floor
Please for your own sake, do not use drywall screws anywhere in a bus. They are made of vary high tensile steel and break realy easy. I can snap them with my bare fingers.
Same go's for most general purpose construction screws including deck screws. If moved sideways, they snap. A nail would bend 16 times before breaking. This is why nails are used in home building, not screws.
Old 10-04-2013, 10:06 AM   #7
Diesel Dan's Avatar
Engine: DT466/AT545
Re: Plywood floor
Originally Posted by nat_ster
...Please for your own sake, do not use drywall screws anywhere in a bus. They are made of vary high tensile steel and break realy easy. I can snap them with my bare fingers.
Nat, I used drywall screws for a lot of the wood stuff I built in my bus, and so far haven't had any problems. I do, however, share your reservations about how brittle they seem to be. In your post you seem to be recommending nails? Wouldn't nails be more likely to loosen up in a mobile application? What type of screws would you recommend, if any?
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 10-04-2013, 11:24 AM   #8
JakeC's Avatar
Re: Plywood floor
My entire bus is built with these. Most components contacting steel were also glued with construction adhesive.
Torx Screws
BTW, Nat, you must have been bored last night. Some serious grave digging going on, haha!!
Brutus
Old 10-05-2013, 12:09 AM   #9
Re: Plywood floor
[quote=Diesel Dan]
Nat, I used drywall screws for a lot of the wood stuff I built in my bus, and so far haven't had any problems. I do, however, share your reservations about how brittle they seem to be. In your post you seem to be recommending nails? Wouldn't nails be more likely to loosen up in a mobile application? What type of screws would you recommend, if any?[/quote:fwhi1jj0]
Sorry Dan, I was over tired last night, and should have chosen my wording a bit more carefully.
No to nails. Not in a mobile application. The reference to nails was only a comparison in the material used to make the fasteners.
Screws are definitely the choice for a mobile application. Depending on where they are being used in the build,will determine the type of screws to use.
Wood to steel, like hanging your cabinets, I would use a machine screw. They are made more like a grade 8 bolt, with threads that can cut into and hold the steel.
Wood to wood in shear, I would use a number 8 deck screw up to 2 inches long. Beyond that length , they snap off quite easily. However, if the panel is pulled tightly against the other under compression, the screw will not be able to move sideways, and longer may be used.
For applications like steel joist hangers, post hangers, hurricane straps ect, to wood, the company that make these parts sell structural screws for this application. They are made of a more flexible steel, with a 1/4 socket head for driving them. Most times these screws are number 10s.
Believe it or not, a 1/2 inch crown framing staple will hold more than a nail. They are coated with a glue that is activated by the friction of driving them with the air stapler. They will bend back and forth about 10 times before breaking. Pulling them out is imposable.
For reference, drywall screws are number 6. Holding power without compression, 2 pounds. Holding power with full compression of material 20 pounds.
Deck screws up to 3" are usually a number 8. Holding power without compression, 10 pounds. Holding power with full compression of material 75 pounds.
Structural screws are usually a number 10. Holding power without compression, 40 pounds. Holding power with full compression of material 150 pounds.
The main reason why drywall and deck screws are made from such high tensile steel, is the method used to drive them. There is a lot of torque on that little spot where the bit fits in the head. This is why cheaper brands strip out the heads so much worse than a good quality screw.
This is only a sample of the way over complicated engineering tables of modern fasteners in residential home building. Hope it helps.
Torx Screws
Gluing and screwing is a good Ida. Screws pull it up tight, glue sets, not only holding in sheer, but also making up for any space that was left between the ply's. As time go's on, construction adhesive only get harder.
And yes Jake, you are spot on. I have bus fever so bad, I could not sleep last night due to not getting the time to work on my buses for two days.
Old 10-09-2013, 12:31 PM   #10
Diesel Dan's Avatar
Engine: DT466/AT545
Re: Plywood floor
Nat, thanks for the advice about screws (and the advice about power tools on another thread). This is very useful information!
Gallery:
Conversion Thread:
Fastening plywood in a bus putterspitt Conversion General Discussions 11 09-02-2010 04:53 PM
Plywood that curls? Doodlebug Conversion General Discussions 7 02-06-2010 04:08 PM
"standard" plywood under rubber floor? NewSkewlHauler Conversion General Discussions 2 01-24-2010 08:18 AM
OSB vs Plywood elkoskoolie Conversion General Discussions 9 07-19-2009 08:48 PM
Stained Plywood flooring? Highwayman Conversion General Discussions 3 11-18-2006 07:12 PM
