Old 04-26-2007, 04:32 PM   #1
portable a/c units?
has onyone consider using one of these off of an inverter as driver a/c? they seem to consume considerabley less power than rooftop units. 800-900 watts.
1991 Blue Bird TC2000 shell version
5.9 Cummins/AT545 Allison
The Wanderer is offline   Reply With Quote
Old 04-26-2007, 08:13 PM   #2
Engine: 7.3 diesel
My opinion is it wouldn't do much good if it isn't big enough to cool the whole bus. My experience with driving a 26 foot bluebird bus with only the front ac working at the time was that the bus cooled down better opening half the windows and going down the road. And when it got really hot out it would be most of the windows open and I'd have my cooler under my seat with plenty of water and ice to suck on. Sometimes I would even put a little bit of ice under my hat which felt good in 90 plus weather.
And right now I'm debating if I really need to run my roof air while driving down the road. I remember family trips in my grandparents class c rv where it only had front air which just about never worked and we would just open the windows even when going to florida in the middle of august. And once we got to a campground we then ran the roof air.
Old 04-26-2007, 08:47 PM   #3
beekay's Avatar
Engine: 5.9
900 watts for how many btu? I think the a/c size necessary to cool my bus down will be more, plus more to get the compressor fired. I really think the best a/c while driving solution is either a compressor driven by the motor, or run a generator for 110v. But I could be wrong. I still am looking for a/c options.
beekay is offline   Reply With Quote
Old 05-26-2007, 01:20 AM   #4
pangaia's Avatar
How about something like this?
http://www.swampy.net/index.html
Since I plan on doing some insulation, probably won't be doing too much summer time desert camping/travel, I felt this would work better w/ a solar system. It almost sounds too good to be true Of course I could just save the $$, purchase three fans, blocks of ice and volia! Instant a/c
'Before you go out seeking revenge you must first dig two holes'--Chinese Proverb
Bright Blessings of the Mother upon you ;)
1990 International Ward Volunteer "Fantastic Voyage"
pangaia is offline   Reply With Quote
Old 05-26-2007, 02:52 AM   #5
the_experience03's Avatar
My understanding is that swamp coolers work best in a dry environment. In SoCal I would think you'd be ok. For those of us in not-as-hot-but-much-more-humid climates they aren't the best idea.
bus ac units thesaltydog24 Heating, Cooling and Appliances 9 06-29-2015 12:46 PM
Trans Air units Malkieri Conversion General Discussions 3 06-28-2013 08:50 PM
30 amp Portable Distribution Box chev49 Electrical, Charging and Solar 1 06-10-2012 01:02 PM
Portable a/c units? waywardfool Conversion General Discussions 9 07-18-2006 02:01 PM
AC units shaggy Conversion General Discussions 15 04-14-2006 02:20 PM
