Old 04-23-2015, 06:13 PM   #1
possibly the right bus for me
I have a bead on a 95 thomas with 250 hp 8.3 Cummins, and air brakes,MTB 643 transmission/retarder, pas through bays, out of Idaho and the claim is no rust either, it will not be available for a week or maybe more.
200,000 miles or a smidge under.
wish me luck! if it is to be our bus than it will!
c_hasbeen is offline   Reply With Quote
Old 04-23-2015, 06:25 PM   #2
Nice. Sounds like awesome running gear.
Old 04-23-2015, 06:29 PM   #3
Dang, nice drive train....oh! Wait! Mmmm....it actually is terrible, where is the ad? I will save you all the smiles by getting this before you enjoy it.
You're welcome
Oh! And take pictures and write a story about the pick up of said land yacht
Old 04-23-2015, 08:05 PM   #4
Chassis: Saf-T-Liner MVP ER
Engine: CAT 3126b Rotella-Chugger
Awesome! The 8.3 is a good motor, I wish I had one (or anything but a CAT). Is it a pusher or what? Only thing I can think of is check what the gearing is like, what RPM on the highway. MT 643 is 5 speed with lockup converter, right?
porkchopsandwiches is offline   Reply With Quote
Old 04-23-2015, 08:33 PM   #5
yes, it is a pusher, it is about 38 ft long and he said the gvwr was 36000 pounds has air brakes 78 inches tall inside also.
it sounds like a LOT of BUS maybe more than I need but
Old 04-23-2015, 08:36 PM   #6
The 78" is the best part. That is how mine is. I am 6'1" and specifically bought the Thomas bus I did so I would be able to stand up inside without doing a roof raise. It will be an awesome platform for you to work off of, I am jealous!
Old 04-23-2015, 10:44 PM   #7
4 speed lockup. But no OD. Excellent transmission though.
Old 04-24-2015, 06:30 AM   #8
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
i have a 96, tops out at 62, little over 2000 rpm, pretty good engine braking too. 4 hour drive over a mountain and the tranny never got over 170* buy it!
my build pics
Old 04-24-2015, 04:58 PM   #9
We are pretty excited about this bus!
Old 05-05-2015, 12:53 PM   #10
We got to go look at this bus, it is pretty well specked out for a mountain bus so we bought and drove home.
no issues in the 10 hours of driving other than the door rattles like crazy when the wind is just right, I figure to look into that some time soon.
she will run 70 MPH at 26 ~2700 rpm, with a couple hundred revs still left on the governor, but really seems to run great at about 65. The retarder works you can watch the trans temp jump up when you use it hard.
The wabasco heater I have not messed with it, I believe it may be inoperable, but the little I know about them it may be something i can deal with at a later time.
tires are in great condition and only a few years old.
drove through some heavy rain, stopped a couple of times to check for leaks but did not fins any, the only place I found moisture was in the bays, but this must not have been the case very often because there is no rust in the corners.
the only rust I could find was on the screen frame that covers the air intake on the side.
here are some pictures.
IMG_20150505_103447.jpg   IMG_20150505_103420.jpg   IMG_20150505_103943.jpg   IMG_20150505_103603.jpg   IMG_20150505_103235.jpg
IMG_20150505_103516.jpg   IMG_20150505_103638.jpg   IMG_20150505_103654.jpg   IMG_20150505_103741.jpg   IMG_20150505_103807.jpg
Old 05-05-2015, 01:31 PM   #11
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
This air foil will add 15 mph to your top end. You can probably hit 130 now.
Nice bus. Congrats.
I'm hungry!
You Gotta Let Me Fly
Old 05-05-2015, 02:00 PM   #12
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
I foresee lots of busted knuckles, foul language, and airborne rust. Congrats on the bus
Old 05-05-2015, 02:08 PM   #13
Super sweet combo! Should make an excellent platform.
And just for the record...in 3 digit Allison designations, the middle number is always the number of gears. 545 (four gears)...643 (still 4 gears).
Also...you can look up your tranny online at the Allison site...
My Transmission
Old 05-05-2015, 02:12 PM   #14
Moderator
crazycal's Avatar
My Transmission
Yes and a mt653 is a 5 speed but first gear does not go into second. You must top to go into and out of second.
I'm hungry!
Old 05-05-2015, 04:27 PM   #15
Nice bus. Congrats.
oh I was told that the air foil kept me from breaking the sound barrier???something I hear is quite common in the skoolie world???
Old 05-05-2015, 05:12 PM   #16
It would appear as if you have gotten a really nice bus that still has a lot of life left in it.
Old 05-05-2015, 05:16 PM   #17
yup thats a helluva bus
Old 05-05-2015, 06:39 PM   #18
Chassis: MVP
Engine: CAT 3116
Nice bus! I wish I had an 8.3 instead of the Cat, would make working on it easier!
Piersg is offline   Reply With Quote
Old 05-05-2015, 09:23 PM   #19
Engine: TE 444
Rated Cap: 12
and a real driver's seat, not the straight backed green torture rack that came in mine
Old 05-05-2015, 11:36 PM   #20
Moderator
crazycal's Avatar
You have a really nice bus with some cool extras, i.e. air foil. My first bus was a 40 foot Bluebird with an 8.3 Cummins. This is what I am picking up next week. It seems like I keep getting smaller and smaller. You will have fun with your bus and won't need much. You got engine, transmission, length, Webasto, luggage compartments. You got it all baby! Now just finish the outside.
I'm hungry!
