Old 12-03-2018, 08:01 AM   #1
Coachwork: Ford E450, Collins 20 Passenger
Engine: Ford 7.3L Powerstroke
Rated Cap: 14,500
Potential galvanic corrosion
So I just removed the old steel floor due to rust issues. I bought sheets of aluminum 050 thickness and glued, caulked, and riveted it down with aluminum rivets to the frame of the bus.
Now I just read about galvanic corrosion between aluminum and steel. Did I just make a huge problem for myself?
spmccormick85 is offline   Reply With Quote
Old 12-03-2018, 08:32 AM   #2
Ronnie's Avatar
Engine: 345 international V-8
Salt and stray electrical currents can eat it up. Good grounding, and keeping road salt off as much as possible will be important. Otherwise should not be a problem
