Old 04-11-2019, 01:12 PM   #21
Sleddgracer's Avatar
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
Originally Posted by Dizzyman View Post
It took 3 days but the Ospho did dry, albeit with a couple of rough spots where bubbles had been. I brushed and wiped the white powder areas. Swept and vacuumed the entire floor then applied Rustoleum oil based white professional High Performance enamel metal primer. 36 hrs later it was dry so we top coated that with white Rustoleum oil based Professional High Performance Protective enamel. Looks good, fingers crossed!
from a professional painter, that's almost as good as it gets - for a professional job, l'd add a quick 2nd finish coat for appearance and longevity, but if you are going to cover the floor anyway - - - - -
Old 04-13-2019, 12:55 PM   #22
Dizzyman's Avatar
Coachwork: Thomas MVP
Engine: Cat 3126B
Rated Cap: 20800
Thanks, from a pro that's high praise! Like you said, going to cover it soon anyway...!
Dizzyman is offline   Reply With Quote
