Old 05-23-2019, 08:14 PM   #1
Year: 2009
Engine: MB 926
Rated Cap: 8 window
power steering leak, and bus wont go
Help Please!! I moved the bus in my driveway and power sterring fluid went everywhere. The high pressure line fitting is rusted out and leaking. When I tried to move the bus again to put it back in it's parking spot it wont go into gear. Are these things related or do I have two issues? The bus has been parked for about 5 months while I'm doing the conversion and this is the first time I moved it. I've started it every week but never moved it. It's a 2009 Thomas C2 with an MB 926 and Allison 2500 series transmission.
Thank you
Misty is offline   Reply With Quote
Old 05-24-2019, 05:41 PM   #2
Year: 2009
Engine: MB 926
Rated Cap: 8 window
I spoke to a dealer today and got the low down on my problem. turns out they are not related as I suspected, just bad luck that both issues happen at the same time. The power steering line is easy enough to replace and they have the part in stock. The transmission is going to take some looking around. The service Manager was extreamly helpful and gave me very detailed directions to trouble shoot it. anything from a fuse to a controler. we'll see
Old 05-24-2019, 11:33 PM   #3
Good luck getting her going without a lot of trouble.
802trees is offline   Reply With Quote
