Old 10-21-2008, 10:12 PM   #1
Year: 1974
Chassis: Thomas
Engine: International
Rated Cap: 60
Power supply????? Battery, Generator?
the dood im buyin the bus from, said he had a buddy who was an electrician install four recepticles each with 2- 4 outlets on each....alott!!!!
it also has a breaker installed at the back of the bus,
now im pretty good with wiring lights and recipticles switches, etc, but this superceded my abilities.
he says ill either have to either get a generator or just plug in at campsite....but i wont power on the road.
he also claims the outlets are powered by 110 volts. (im going to have like lights and a tv , fridge , hot water heater, and pump, microwave? etc.)
batteries mabey hooked up to two small solar panels?.....dont you need a converter for the battery to plug things into it help....confuseddddd.....
any reccommendations?
apprechiate it !
travlenhippie is offline   Reply With Quote
Old 10-21-2008, 10:33 PM   #2
Year: 1974
Chassis: Thomas
Rated Cap: 60
Re: Power supply????? Battery, Generator?
thanks man!
Battery Power Inverter with Roof Mount AC logistix Alternative Fuels | Electric, Propane, Wood Gasification, etc. 8 11-25-2013 11:24 PM
Generator vs Battery w/Inverter arfisher83 Everything Else | General Skoolie Discussions 1 01-20-2009 03:33 PM
generator vs. battery power joshritchie Conversion Tutorials and How-to's 16 12-22-2008 07:24 PM
ATX PC Power Supply to a 12 Volt Power Source vonslatt Everything Else | General Skoolie Discussions 3 02-15-2006 06:57 PM
Wondering How Much Battery Power You Need? Steve Conversion Tutorials and How-to's 5 12-23-2003 10:48 AM
