Old 03-31-2010, 08:17 PM   #1
Year: 93
Chassis: ?
Primer and Paint
I have to get some primer on bare metal before April 17th. It has to be something that sticks well and works well with other paints as I have not decided what kind of paint or which product I want to use. I am leaning towards The Valspar primer off the shelf from Tractor supply but I am worried that I would be limited to what I can top coat it with.
Anyone have any experience with this?
swhite832 is offline   Reply With Quote
Old 03-31-2010, 08:30 PM   #2
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
Re: Primer and Paint
How do you plan to apply the primer/paint? If you have the equipment (or access to the equipment) to spray it on, I would highly recommend a self-etching type primer over bare metal. I am not familiar with the restrictions in your state but you should be able to get it at an auto body supply store. Second choice would be a urethane type primer, that is what I am using on my entire bus. The main thing is when you apply your top coat of paint, use a compatible system. In other words don't apply lacquer over enamel, etc. But, your state limitations and budget may not allow this type of paintjob, in which case I would just go with a good enamel primer/topcoat system and try to get your hands on some enamel hardener additive otherwise it takes forever for enamel to harden.
Old 04-01-2010, 06:26 AM   #3
Year: 93
Chassis: ?
I would like to use just one product(primer) for both. There are so many opinions on this subject and so many different choices i am having a hard time making an educated choice....especially on such short notice.
Old 04-01-2010, 09:14 AM   #4
Coachwork: Chevy
Chassis: Bluebird
Rated Cap: 16
What about rustoleum automotive primer? That's what I'll use when it comes time to paint my skoolie.
Rutgers tailgating bus http://www.skoolie.net/forum/viewtopic.php?f=36&t=5545
RUskoolietailgater is offline   Reply With Quote
Old 04-01-2010, 09:54 PM   #5
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Rated Cap: 48
Again it depends on the method you use to apply the primer. Are you spraying it on or brush/rolling it on? I would at least talk to someone at an auto body supply store before I made a final decision.
Old 04-04-2010, 10:50 AM   #6
Year: 93
Chassis: ?
Due to time constraints and availablity I sprayed rustoleum metal (rusty) primer(enamel) around the window openings and attached the windows permanently.
Therefor, my choice is a one stage enamel with hardener. Prolly two tone. Most likely the Valspar products....
Old 04-04-2010, 12:37 PM   #7
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Rated Cap: 48
I think you will be pleased with the results. Enamel paints have been used on vehicles for decades. As long as you are using a proper hardener, it will become very durable and hold its shine quite well. Just remember, dont test the hardness of your paint right away because enamels will remain soft for a month or so, even with the hardener, longer without it. It will eventually harden up well. After about 3 months you can put a good coat of wax on it to protect the paint further and really enhance the shine, just dont wax it until after the first 3 months with enamel. And don't forget to get pics of the paintjob....we love to see pics!
Old 04-04-2010, 01:51 PM   #8
Year: 93
Chassis: ?
It will be awhile before the top coat goes on but I have made some progress on the deck and the furniture is in for the races in two weeks.
Old 04-04-2010, 10:51 PM   #9
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Rated Cap: 48
Originally Posted by Smitty
Not true with hardner........
Smitty
I guess my term 'soft' is relative... It will be hard much sooner with good hardener, but not to its full hardness for about a month. Without hardener at all it will literally remain soft enough to scrape with your fingernail for quite some time...but it will eventually get hard enough to resist scratching.
jasco Prep and Primer MissJaneStrummor Short-Bus Conversion Projects 12 02-21-2014 08:33 AM
Paint & Primer in One Review lornaschinske Conversion General Discussions 5 06-08-2012 11:36 PM
HELP with paint lapeer20m Conversion General Discussions 4 07-04-2008 09:53 PM
Paint...and more paint...and more paint... skooliedave Conversion General Discussions 13 02-02-2008 04:22 PM
When to paint andybus9 Conversion Tutorials and How-to's 16 11-30-2005 09:24 PM
