Old 12-11-2006, 09:46 AM   #1
Les Lampman's Avatar
Welcome aboard Blaines!
Hang in there; I've seen this topic come up before and hopefully one of the folks that know these brake systems will chime in here. Sorry I can't give you any clues as I have air brakes on my buses.
Les Lampman
1982 Thomas Saf-T-Liner Pusher "Illusion"
Skoolie.net Gallery
Illusion's SmugMug site
Les Lampman is offline   Reply With Quote
Old 12-13-2006, 03:29 AM   #2
I have a 1990 Chevy with a Detroit 8.2. I also have hydraulic brakes. These chassis came with some different brake systems. My bus has the Bendix system. Check out link to the PDF file and see if that is the system you have. You can also call a GM dealer to look up the VIN and find out what system you have.
You will find everything about the sytem in the link to the PDF file i attached. If you don't know how old the fluid in your system is do yourself a favor and replace the fluid before your master cylinder gets pitted and the seals start leaking. That cost me some money and time that I did not have to spare.
http://www.bendix.com/bendix/downloads/ ... 206602.pdf
busone is offline   Reply With Quote
Old 12-14-2006, 10:56 AM   #3
sportyrick's Avatar
Chassis: F33695
brakes
how about this???? your battery is dead and your vaccum motor won't run so you don't have any brake boost vaccum and that makes the light come on. sportyrick
sportyrick is online now   Reply With Quote
Old 12-14-2006, 07:59 PM   #4
the_experience03's Avatar
Well your battery sure isn't doing you any favors though I can't say that is the brake problem. It might just not have enough power to energize the starter solenoid though. A resting battery should show roughly 12.6 volts when fully charged though this does vary by .2 volts from manufacturer to manufacturer. You can test the new battery, but most battery testers, especially the high quality carbon pile load testers, need a full charge to test that battery and if it isn't taking a charge you can pretty well assume it's shot.
Old 12-16-2006, 06:25 PM   #5
If you read the manual that I posted the link to you would know everything you need to know about the brakes. Here is the link again. It even shows all the electronic circuits.
Old 12-16-2006, 10:56 PM   #6
BusNut's Avatar
Glad to hear you got it started. But if your battery voltage is that low when not running, you shouldn't try starting it too many times on it. Low voltage can damage your starter.
BusNut is offline   Reply With Quote
86 International Hydraulic Brakes hmacris International | Navistar Drivetrain 2 07-26-2011 01:13 PM
Whole new problem this time with the brakes Roachhill Conversion General Discussions 6 04-11-2011 09:11 PM
1991 BlueBird TC2000 Hydraulic/Hydraulic Brakes Sticking C00LR Mechanical and Drivetrains 0 10-15-2009 11:11 AM
hydraulic to air brakes adamanderr Conversion General Discussions 2 01-03-2008 11:35 PM
Diesel Starting Problem - Question BusMe Conversion General Discussions 27 11-07-2006 08:27 AM
