Old 11-05-2006, 11:30 PM   #1
GoneCamping's Avatar
Propane tank mount & waste tanks installed...
Got something visible done today, finally!! I actually got the propane tank mounting system engineered and installed into the bus last weekend, but got the access door for it cut today, and finished bolting it all up in place. I have a complete write-up with pictures posted HERE
I also got the gray tank hung beside the black tank. The black tank has been there for over a month, but just got around to mounting the other tank. I was a must do as I've been running plumbing the last few Sundays, and need to terminate the drain pipes to the tanks. I have some pictures and write-up for that too located HERE
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Where to mount propane tanks vega12 Conversion General Discussions 43 10-19-2018 02:27 PM
Where to mount the propane tank lbranin Alternative Fuels | Electric, Propane, Wood Gasification, etc. 13 06-13-2018 08:32 PM
Installing a different tank mount and/or fuel tank jazty Conversion General Discussions 16 09-15-2014 06:42 PM
How About these for waste tanks? Stu & Filo. T Conversion General Discussions 8 01-22-2014 11:51 AM
Have 2 new waste tanks I don't need Anthony Everything Else | General Skoolie Discussions 0 05-17-2013 11:03 PM
