Old 06-04-2016, 05:33 PM   #1
jester's Avatar
Chassis: RE200
Engine: 7.3L Navistar T444E
propane tank mounts??
who uses the 2 tank route, and who uses the one big horizontal tank?
i cant find any mounts that look HD enough to hold them. any thoughts or solutions??
check out my build pics
http://www.skoolie.net/forums/member...albums833.html
or my random writings... at
www.roadrunnerlogik.blogspot.com
jester is offline   Reply With Quote
Old 06-04-2016, 06:00 PM   #2
I built a under body box for storage and my 2-20lb tanks, one is hooked up for the appliances, the other is the spare or for the BBQ, I find it better to use the 20lb tanks, you can exchange them for full ones just about every where, much easier then trying to find a place that will pump propane to a frame mounted tank, also you don't have to worry about you tank expiry dates,
Old 06-04-2016, 06:21 PM   #3
jester's Avatar
Chassis: RE200
i think that sounds same as my thoughts on the matter.
i did just find this and it looks very rugged.
http://www.amazon.com/Propane-Crawle...ilpage_o00_s00
Old 06-04-2016, 07:00 PM   #4
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
I built mine using uni strut mounted to side supports & thru the floor, I read that uni strut is rated at something like 2700lbs, I could be a little off it's been awhile since I read it.
Old 06-04-2016, 11:46 PM   #5
Man! That's a lot of propane! Hank Hill will be proud of you.
Old 06-05-2016, 12:01 PM   #6
jester's Avatar
Chassis: RE200
" i live in the real world, and real men sell propane and propane accessories"
Old 06-05-2016, 12:28 PM   #7
They actually setback farther than it looks in the picture plus I have supports connected to the side of the bus body so in theory if it ever gets hit in that area it will push the tanks in.
Old 06-05-2016, 12:59 PM   #8
jester's Avatar
Chassis: RE200
hell of a job stu! super classy if you ask me
Old 06-05-2016, 04:22 PM   #9
Chassis: B3800 Short bus
I've been using this exact mount under our bus for over a year. It is plenty strong and holds our single 20lb tank tightly. I've put ~15000kms with a propane tank mounted under the bus with no incident - which is a good thing! I also lock the tank to the bus with a cable and pad lock when travelling. It keeps the tank from walking off and would hold the tank well above the pavement if the mounts broke while underway.
