Old 03-26-2019, 12:52 PM   #1
Propane Tank Placement
Mounting the tank in the rt rear corner. Question is should I mount it nearest the frame rail. near the side for access, or centered between the outside and the frame rail.
Old 03-26-2019, 08:08 PM   #2
Ninjakitty's Avatar
Engine: 6.6 New Holland Diesel
Rated Cap: 60 kids, 10 window
I went closer to the skirt, but that's is because I'm using my battery box as a shield.
Nick
Old 03-26-2019, 08:12 PM   #3
I eyeballed it and mounted it centered. There's only a couple inches leeway. My battery box is on the opposite corner of the bus. The RR was the only place this tank would fit.
Old 03-26-2019, 08:14 PM   #4
You mean a shield from the exploding propane tank?
Old 03-26-2019, 08:17 PM   #5
Ninjakitty's Avatar
[emoji848] perhaps?
Really just from spray from the front tire. I have a similar tank to marc01's tank, except it's the 12.2 gallon version.
Nick
Old 03-26-2019, 08:19 PM   #6
Ninjakitty's Avatar
That rear Port side? I have my a/c condenser there.
Nick
Old 03-26-2019, 08:20 PM   #7
Starboard, Port is on the left.
Old 03-26-2019, 08:24 PM   #8
Ninjakitty's Avatar
Yes, that's why I asked. Right and left are dependent on where you are facing. Port and starboard are dependent of bow and stern. I was just trying to figure out where you placed it. I have a tool box and generator where your tank is.
Nick
Old 03-26-2019, 08:39 PM   #9
Mountain Gnome's Avatar
Chassis: TC1000 HandyBus
Rated Cap: 26 foot
I use "driver's side" and "passenger side." Even works in Brittan.
Starboard? Port? tell me today, I forget tomorrow. But then I'm a mountain gnome, not a sea gnome.
Seems like centering the tank limits the remaining space. If you mount it either toward the frame or skirt, a bigger space is left open that could be used for something you haven't thought of yet...maybe won't think of for another 5 years. If you center it, you get two smaller spaces.
My penny for the day...
Old 03-26-2019, 08:41 PM   #10
I mean, it used to be "starboard" and "larboard". Count your blessings.
Old 03-26-2019, 08:43 PM   #11
RR, Right Rear . Doesn't matter what direction you're facing, bow is front, stern is rear, left is port, right is starboard, Bow is fore, stern is aft, below is, well, below. And if you call my lines ropes once more I'm throwing you off the boat.
My girlfriends family in high school were boaters.
My port side is all under storage. The starboard side has the fuel tank, storage bay and exhaust behind the rear wheel. I relocated the exhaust and put the tank where the last 6' of exhaust used to be.
Old 03-26-2019, 08:46 PM   #12
Ninjakitty's Avatar
That's a good spot. At this point, I would have liked to have my tank on the rear driver's area. Would have made for shorter runs but I had read somewhere that some ferries won't allow you aboard if your tank isn't between wheel wells. Not sure if this is true and not sure how many ferries I'll take the bus on....
Nick
Old 03-26-2019, 08:57 PM   #13
I took the ferry to Bainbridge Island in Seattle. They only asked for two things- $80 please. , and keep it as close to that wall as you can. They had me so close I couldn't open the door. Had to go out the back.
I'll hang the tank tomorrow as we are expecting a warm afternoon, I'll post a pic then. Here's where it's going
Old 01-11-2020, 08:23 AM   #14
Ninjakitty's Avatar
I took the ferry to Bainbridge Island in Seattle. They only asked for two things- $80 please.[emoji2] , and keep it as close to that wall as you can. They had me so close I couldn't open the door. Had to go out the back.
Since posting, I did take the bus on a ferry. From Bolivar Penin3to Galveston TX. No one asked me for anything except to wait inline until the ferry opened tondrive on.
Nick
Old 01-11-2020, 09:34 AM   #15
TheHubbardBus's Avatar
Coachwork: IC / Amtran
Chassis: CE300
Engine: International T444e
Rated Cap: 23
Here's a snipped from NFPA1192 (fire standard for RVs) that's relevant:
Go away. 'Baitin.
Our Build: Mr. Beefy
