Old 03-26-2019, 12:52 PM   #1
Propane Tank Placement
Mounting the tank in the rt rear corner. Question is should I mount it nearest the frame rail. near the side for access, or centered between the outside and the frame rail.
Old 03-26-2019, 08:08 PM   #2
Ninjakitty's Avatar
Engine: 6.6 New Holland Diesel
Rated Cap: 60 kids, 10 window
I went closer to the skirt, but that's is because I'm using my battery box as a shield.
Nick
Old 03-26-2019, 08:12 PM   #3
I eyeballed it and mounted it centered. There's only a couple inches leeway. My battery box is on the opposite corner of the bus. The RR was the only place this tank would fit.
Old 03-26-2019, 08:14 PM   #4
You mean a shield from the exploding propane tank?
musigenesis is online now   Reply With Quote
Old 03-26-2019, 08:17 PM   #5
Ninjakitty's Avatar
perhaps?
Really just from spray from the front tire. I have a similar tank to marc01's tank, except it's the 12.2 gallon version.
Nick
Old 03-26-2019, 08:19 PM   #6
Ninjakitty's Avatar
That rear Port side? I have my a/c condenser there.
Nick
Old 03-26-2019, 08:20 PM   #7
Starboard, Port is on the left.
Old 03-26-2019, 08:24 PM   #8
Ninjakitty's Avatar
Yes, that's why I asked. Right and left are dependent on where you are facing. Port and starboard are dependent of bow and stern. I was just trying to figure out where you placed it. I have a tool box and generator where your tank is.
Nick
Old 03-26-2019, 08:39 PM   #9
Mountain Gnome's Avatar
Chassis: TC1000 HandyBus
Rated Cap: 26 foot
I use "driver's side" and "passenger side." Even works in Brittan.
Starboard? Port? tell me today, I forget tomorrow. But then I'm a mountain gnome, not a sea gnome.
Seems like centering the tank limits the remaining space. If you mount it either toward the frame or skirt, a bigger space is left open that could be used for something you haven't thought of yet...maybe won't think of for another 5 years. If you center it, you get two smaller spaces.
My penny for the day...
Old 03-26-2019, 08:41 PM   #10
I mean, it used to be "starboard" and "larboard". Count your blessings.
