Old 02-16-2018, 01:01 PM   #1
Pull The Trigger?
So the salesman just got back to me and said he personally took the bus out for a 20 mile drive. Had no issues, said it drove nicely. Top speed was around 65. Heaters all worked. The school would be concerned that "if" there was an issue they would have a load of students stranded on the side of the road, concerned because the bus is so "old". They will accept my $2k offer. What other questions or issues should Follow up with before closing the deal. I imagine I would fly out there, check it out myself before forking over any cash.
88 BBAA, 8.2L, 163K, $2K
o1marc is online now   Reply With Quote
Old 02-16-2018, 01:08 PM   #2
See if there are any maintenance logs you can get your hands on. Check the tires including the DOT date stamps. Remember...a set of six can easily run a couple of grand. Take a look at all the fluids when you get there. Should all be clear and clean. Tranny fluid should never have a burnt smell as that's a sign of serious overheating and $$$ trouble on the horizon. Milky water /and/or oil means cross contamination (head gasket or worse). I'm sure others here can chime in with more.
Best of luck.
Old 02-16-2018, 02:21 PM   #3
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
Did you get more info on the quirks?
Edit - or was the quirks just them worried about age
jjhwick119 is offline   Reply With Quote
Old 02-16-2018, 02:58 PM   #4
Robin97396's Avatar
I'd press them for good rubber. They know you're making a long drive so I think they'll do that for you.
So, that bus and good rubber? Get the title quick. Relax, it's just your first bus.
You're looking forward to that adrenalyn filled drive home, aren't you?
Robin
Nobody's Business
Old 02-16-2018, 03:57 PM   #5
HOW DOES THIS BUS COMPARE TO A TC2000? There are about 8-10 98-99 TC2000's coming up on the 20th much closer to me than Id. All are priced in the $1200 range right now.
Old 02-16-2018, 04:54 PM   #6
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
I have the 8.2 in an 86 and from the diesel shops that I have talked to and dealt with about mine is that it's old technology and there is not to many mechanics left anymore that even knows how to work on them.
I have had to learn to do the governor and fuel rail drive adjustments myself because I have only found one shop that would touch it.
They are a full Detroit shop though so quite a bit more expensive for labor and really the only true parts source I have found but they are an hour and a half away.
I can't get any of my local garages to touch it.
Good luck
Old 02-16-2018, 04:59 PM   #7
Coachwork: Amtrans
Chassis: Genesis
Rated Cap: 20 (9 window handicap)
In addition to what some of the other have said. Of concern to me if driving a long way back home, I would want all the gauges to work correctly. Not having an oil pressure, temp, or trans temp gauge before a long trip would be a no go for me.
Route planning would be important too. Not the time to take the road less traveled across the middle of nowhere.
I happen to know where that bus is, so I would recommend a weather check as well when you know you would go to get it. There are plenty of areas that would be bad to be in a snowstorm on the way back. PM me if want to discuss the areas I would be worried about.
I'd probably do the math on whether its cheaper to pay $50 for checked baggage or simply stop at walmart or harbor freight and pick up some hand tools, multimeter, test light etc. I'd probably grab some oil appropriate for the engine, trans, and some spare coolant as well. If are real worried after looking at it, you might see if belts or hoses are available before you are in the middle of nowhere.
In my opinion, get the bus you want. But I would consider paying a premium if you can buy it close to home. You have done the math on how much the trip out and back to get it is. I would pay MORE than that total amount to reduce the risk to be 150 miles from home rather than 2k.
Tigerman67 is offline   Reply With Quote
Old 02-16-2018, 05:28 PM   #8
With the other auction only 4 days out, i'll wait and see what happens there. Like you say, I can spend $3500 on on of those and be cheaper than the west coast bus.
Tranny fluid in this one looks decent, oil looks like it could use a change. Didn't get date codes, but tires look decent.
Old 02-16-2018, 05:55 PM   #9
Robin97396's Avatar
You'd miss an opportunity to see our wet and wonderful west coast? Are you afraid you'll rust out here?
I can't say I'd be into a long drive with a new to me vehicle either. I'm still impressed with the cross country drive last winter during the freezing season with a hole in the windshield on the driver's side. That was pure brass.
Robin
Nobody's Business
Old 02-16-2018, 06:17 PM   #10
I'm familiar with the area. My brother lives on Bainbridge Island. You guys are impressed with your average rainfall amounts. Imagine my surprise when I found we get more rain here in no. Ga. annually than the PNW. I'm a west coast native (Berkeley,Ca.). Can't say lately that I'm proud to be a Ca. native, they are really tearing that state up with their politics.
