Old 11-28-2019, 12:10 PM   #81
Somebody posted something awhile back that said buses were factory specced to have insulation worth a 20-degree difference from the outside temperature. Adequate in a running bus with industrial-strength heating and AC but nowhere near enough to make living in it comfortable.
Think it was me, but not so much the insulation, but the heat and AC systems were designed to make a 20* difference from ambient.
Old 11-28-2019, 12:57 PM   #82
How about you mix it up and make it a convertible or bolt some seats to the roof
Cap7 is offline   Reply With Quote
Old 11-28-2019, 01:54 PM   #83
Truthseeker4449's Avatar
Chassis: MVP ER
Engine: CAT 3126
Working on charter buses has taught me they have a fraction of the structural integrity of a school bus, so I'm not terribly concerned about any loss of structural integrity. What would be a good material to replace the ceiling with?
I would think there's insurance issues involved with bolting seats to the roof if decks are frowned upon.
Truthseeker4449 is offline   Reply With Quote
Old 11-28-2019, 04:29 PM   #84
Chassis: ThomasBuilt 30'
Rated Cap: me + 1
Originally Posted by Ronnie View Post
I do not have a thermal image but I have used an infrared thermometer and my ribs showed 10 degrees cooler then the surrounding sheet metal. This extended about an inch to each side of the rib. Measured when it was in the 20's outside, and 65 inside.
I have to say if I did anything with roof insulation I would add 2" rigid foam board to the inside, and put wood over that. So it would be from the outside in, outer metal roof, fiberglass 2", metal ceiling, foam board, wood ceiling.
I do have a high roof so there is room to do this for me.
I think that you are on the right track
Old 11-28-2019, 05:01 PM   #85
Rated Cap: me + 1
Buses are not unibody. They're body on frame.
Have you ever driven one without the metal headliner?
If its structural its pretty minimal.
Ever seen a high end motorhome with a metal headliner? ever?
"Buses are not unibody. They're body on frame."
True, but, I believe I said "This construction seems like a unibody mounted on a frame." ????
"Have you ever driven one without the metal headliner?"
No
"If its structural its pretty minimal."
BS. Take a simple piece of card board with an out side sheet of paper glued to the corrugation sheet of paper with another sheet of paper glued on the other side of the corrugated sheet of paper. Remove the sheet of paper on one side and what happens? It loses most all of its strength in one direction. There is a structural reason for the sheet metal ceiling and it is not to hang magnets on. The reason is so that the buss will support 1.5 times its weight in a roll over to meet regulations. You will note that the walls also use this type of construction.
"Ever seen a high end motorhome with a metal headliner? ever?"
No, and they will not support 1.5 times their weight in a rollover. The pretty crap that they use has no structural strength. Thanks for proving my point.
Old 11-28-2019, 05:03 PM   #86
This is what we did, but used 1/2" instead of 2" insulation. I wouldn't be comfortable losing more than 1 1/2" from the existing ceiling. Still significantly cooler than it was before.
Old 11-28-2019, 05:10 PM   #87
Rated Cap: me + 1
Originally Posted by Warthog View Post
I've a PhD in chemistry....I understand thermal bridging quite well, thank you.
Insulating the air space with a foam is still drastically increasing the R-value by cutting out convection and radiation heat transfer across and in the air gap between the inner and outer steel walls. All that remains is transfer by direct conduction in the thin metal strips that comprise the spacer beams.
Yes, that conduction is non-zero, but far less than the original total.
Correct, thankyou
Old 11-28-2019, 05:15 PM   #88
Rated Cap: me + 1
Bluebird's Wanderlodge is a school bus body with half as many ribs and a cardboard ceiling and they're still WAY overbuilt for the purpose.
They also don't have to be able to meet schoolbus specs. BTW, whats wrong (besides weight) with being overbuilt.
Old 11-28-2019, 05:35 PM   #89
Rated Cap: me + 1
If you're just filling the steel with foam its not really doing much to insulate. Better for noise insulation than thermal.
https://tinyhousedesign.com/how-to-d...rmal-bridging/
https://www.bautexsystems.com/blog/h...ermal-bridging
https://www.rhinobldg.com/beating-th...tal-buildings/
These articles are about as scientific as a McDonalds adverisement. There is a little truth in them, very little, but they do not bear out your statement.
Old 11-28-2019, 05:39 PM   #90
Rated Cap: me + 1
Originally Posted by banman View Post
I've been wondering... so I might as well invite the abuse on this thread (I think the OP's original Q has been long answered...)
Why not use fiberglass bat instead of ridged foam board like the factory does?
Fiberglass is much cheaper, and lighter. The thermal bridging issue of the ribs is a separate issue -- I'm just wondering why no-one likes the fiberglass bat?
Happy Thanksgiving!
I like fiberglass bats
Old 11-28-2019, 07:31 PM   #91
No
Bluebird Wanderlodge. Look it up.
Anything bending a bus has to bend the outer skin and ribs. The metal headliner and interior panels are there to keep kids from bouncing into the ribs more or less. Watch a bus crash test with kid dummies in it.
If you all are so into metal vehicle interiors why not double down and have steel headliners and door panels put in your cars?
Old 11-28-2019, 07:34 PM   #92
More truth in them than anything you're saying. There are PLENTY more if you wanna use GOOGLE.
Old 11-28-2019, 07:35 PM   #93
If you're trying to keep school bus specs then build around the seats. They're WAY MORE structural than the headliner.
Old 11-28-2019, 09:57 PM   #94
Rated Cap: me + 1
LOL, funny guy.
Old 11-28-2019, 10:00 PM   #95
Rated Cap: me + 1
Funny, non of the school bus manufactures see it your way. Go tell them how stupid they are.
Old 11-28-2019, 10:03 PM   #96
Rated Cap: me + 1
Just reread my last post on your "reference articles/evidence". It still applies.
Old 11-29-2019, 01:01 AM   #97
Year: 93
Coachwork: Corbiel
Rated Cap: 36 pass
I kinda like my original bus roof.
Free Bird is offline   Reply With Quote
Old 11-29-2019, 02:09 AM   #98
Rated Cap: me + 1
What happened? Did a kid bump their head on it? Should of had a metal ceiling, excuse me, I meant metal headliner.
Old 11-29-2019, 03:52 AM   #99
Troll much??
Old 11-29-2019, 03:55 AM   #100
https://en.wikipedia.org/wiki/Blue_Bird_Wanderlodge
Heres a tale of one rolling on its side in a ditch. They drove it away. No metal interior!
https://www.wanderlodgeownersgroup.c...t=14992&page=5
