Old 07-16-2008, 08:12 PM   #1
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
Putting the roof deck on a diet: non-load-bearing surfaces?
My current roof deck is constructed from 2" x 6" TREX decking. It looks great, it's tough and...it weighs a lot. TREX of this size weighs around 3.3 lbs per linear foot (specific gravity of .93...please let me know if I'm off). The deck runs the length and nearly the width of the bus.
I'm considering scaling down the TREX portion to a central catwalk, and replacing the rest with something that will provide shade and not fly off while going down the road. I still need to walk up there to access two Thule cargo carriers and to tilt solar panels. At first I was considering expanded sheet metal. Now I'm thinking corrugated fiberglass or corrugated metal. Can corrugated fiberglass take the rare 60mph burst of speed? It would be screwed down every 27" or so lengthwise.
Thoughts?
Thanks
Sean
Bus conversion/info here
SeanF is offline   Reply With Quote
Old 07-17-2008, 04:50 PM   #2
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
Re: Putting the roof deck on a diet: non-load-bearing surfaces?
Originally Posted by jimmyaustintx
When I put my deck on it will be with bleachers that a school has replaced, I have a source in Houston so when the time comes I hope he still has them maybe by summers end I will make the trip and call before I go since he can make more selling it for scrap
Aluminum bleacher seat sections would be perfect! Sadly I have no connections that would have them.
you put a lot of money on your deck and it looks like you do not drive it that much so why the change...
That's a good question. One reason is that I'll be towing a motorycle trailer next time I move, which I have not done before, and I'd like to lose some weight elsewhere to make up for it. Another reason is that I worry about the weight of the deck so far up, and given my relatively short wheelbase, I worry about stability if I should ever have to do an evasive maneuver or find myself too fast for a corner. These aren't really GREAT reasons, but they're what I've got!
Thanks for the feedback so far.
Sean
Old 07-17-2008, 09:25 PM   #3
CVanDamme's Avatar
We've kicking around the idea of what we are going to use for the deck. In town they manufacture this product called
Thru-Flow decking. It's light weight, made of plastic (many colours to choose from) snaps together and screws down. We are hoping to buy some seconds (small flaws, off colour pieces) I don't know what they are worth yet, but'll look into it since I will need to find out anyways.
Heres the Linkhttp://thruflow.com/
Chris Van Damme
92 Blue Bird TC2000FE
The Slab Cab'n
Follow my build up here https://www.skoolie.net/gallery/v/Skoolies/Slab_Cabn
Or join the facebook group Friends of the Slab Cab'n https://www.facebook.com/group.php?gi...2145574&ref=ts
CVanDamme is offline   Reply With Quote
Old 07-19-2008, 03:08 PM   #4
reprobate's Avatar
We used expanded metal with 1 1/4" square tubing for the frame. For attaching we used Quik-n-Easy brackets which clip to those raingutter brackets sold by Thule or Yakima. It may not sound like a very strong setup, but having used this style many other times always in very demanding situations I have faith. Our deck will be for carrying canoes, kayaks or for drinking and relaxing or sleeping under the stars. It's 7'6" wide and 10' long weighing in at maybe 100-125lbs.
reprobate is offline   Reply With Quote
Old 07-19-2008, 04:57 PM   #5
odyssess's Avatar
Engine: T444E 3800
Reprobate, can you post a picture of your setup with the clamps and brackets(if it's not too much trouble)? I'd like to see if that's a viable solution for me as well...Thanks
https://www.skoolie.net/gallery/v/Skooli ... Green+Bus/
Keep on Keeping on.
odyssess is offline   Reply With Quote
Old 07-19-2008, 05:57 PM   #6
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
Thanks for the continued feedback.
Reprobate's fine deck can be seen here:
and
Roof deck badasp118 Conversion General Discussions 15 04-13-2013 04:13 PM
Roof deck chev49 Conversion General Discussions 1 04-03-2013 10:27 AM
securing a roof deck TygerCub Conversion General Discussions 11 08-05-2012 09:10 PM
Roof Deck - New Owner Great White Buffalo Conversion General Discussions 13 11-18-2006 03:05 PM
roof deck azredneck Conversion General Discussions 2 06-02-2006 05:37 PM
