Old 02-23-2018, 10:24 AM   #1
PVC/Plastic Sub Floor?
So I was thinking of what to use as my base for the bus floor.
Most people just lay 1/2 or 3/4 plywood as the first layer, then add runners, more insulation and then a higher quality flooring before laying the final product I think.
What if you used that PVC or shower stall type paneling as that first layer? Its 100% water proof and your putting Plywood over it anyway?
Just think of it as a way to 100% waterproof the floor from below but not if thats necessary?
PNWorBUST72 is offline   Reply With Quote
Old 02-23-2018, 11:49 PM   #2
A few arguments for plywood:
1) It's super cheap.
2) It's not brittle like PVC and will hold up to vibration (from driving) much better.
3) It's easy to cut with inexpensive tools. Home Depot/Lowe's will even cut 4'x8' sheets for you in the store.
I don't think waterproofing the floor from underneath is necessary. The very bottom level steel floor (whatever was on the bus when you pulled up the rubber floor) already serves that purpose. You shouldn't be getting much water coming up from under the bus anyway, probably just what comes off the wheels when you drive in the rain.
Professionally converting vehicles and making custom furniture with a combined 14 years of mechanical/electrical engineering experience.
https://www.thunderstruck-studios.com/
ThunderstruckStudios is offline   Reply With Quote
Old 02-24-2018, 10:14 PM   #3
BowserJournal's Avatar
Chassis: Ford B600
Rated Cap: 20 person
We are laying 3/4 inch plywood in ours.
"Living Our Own Story"
The Bowser Journal
Watch our adventures by subscribing...
Youtube - bit.ly/TheBowserJournal
BowserJournal is offline   Reply With Quote
Old 02-24-2018, 10:29 PM   #4
When I work on these, we do 1/2 inch foam board, half inch ply, then add the flooring. We tape all joints in the foam and stager the ply joints so they don't fall on top of the foam joints. It makes for a more stable floor. Also, we run the flooring 90 degrees to the plywood joints so no flooring joints fall on top of the plywood joints. Usually, we lay the ply across the bus floor and run the flooring down the length of the bus.
I have done 1/4 inch foil faced foam board foil side up, 7/16 OSB smooth side up, and glued down vinyl roll flooring. I did this to keep as much interior height as possible. A few years back, I saw on another forum where a guy laid 1/2 inch foam down, then 1/4 inch underlayment, and glued down vinyl roll flooring.
I do advise against using adhesive backed vinyl squares or strips. Every time I have seen these used, they peel up in hot weather (90F+) and really cold weather (below 40F).
ben2go is offline   Reply With Quote
Old 02-24-2018, 11:42 PM   #5
Chassis: 3000RE
Engine: T444E w/ MT643
Rated Cap: 84 pass, 40'
Thanks. Good info.
Sent from my XT1585 using Tapatalk
2martins is offline   Reply With Quote
Old 02-25-2018, 09:36 AM   #6
don't mean to steal the thread, but its time I up date the flooring in my bus, have plywood now, might use vinyl click type planks, but was wondering how they wood hold up in the winter during cold storage -30
tks
Old 02-25-2018, 11:19 AM   #7
Originally Posted by 2martins View Post
Thanks. Good info.
You're welcome.
tks
I can't say. I've never been in that cold of weather before. I would allow for expansion and contraction of the flooring. It may help to lay in the flooring after the walls are in and allow about 3/16 inch for expansion and contraction. The gap can be covered with small baseboards. I have used 1/2 x 3 furring strips attached to the wall with a bit of PL (liquid nails) and 3/4 inch finish/trim nails. It also gives a finished homey look. They can be prepainted outside the bus. Then installed and a quick touch up over the nails with paint.
Old 02-25-2018, 11:40 AM   #8
If you want water proof floors I have a better option for you
Look up a product called advantex
Itís cheap, easy to get, and easy to work with
Itís a subfloor product
And itís 100% water proof
Iíve been using it for years
Rberriz is offline   Reply With Quote
Old 02-25-2018, 11:56 AM   #9
Robin97396's Avatar
If you want a waterproof floor why not put down a big continuous roll of linoleum? Instead of trimming the floor covering to the edge of the floor, allow the flooring to ride up the wall about 4". That will keep any spilled liquids from getting under your flooring.
Robin
Nobody's Business
Old 02-26-2018, 07:37 PM   #10
A metal floor is waterproof. You just need to mitigate sweating/condensation. That can be accomplished by using marine grade plywood over a well coated metal surface ( i.e. rustproof the metal first.)
