Old 08-14-2015, 10:38 PM   #1
Question...
Would tinting the windows be as efficient as blocking the off with paneling...
Bussin' is offline   Reply With Quote
Old 08-14-2015, 11:09 PM   #2
USMCRockinRV's Avatar
Chassis: Safe-T Liner MVP
Engine: 12V Cummins
Rated Cap: 75
Question...
Where do you live? In Houston tinting isn't enough - I used Bubble Foil, 3/4" Foam Board and paneling to eliminate heat transfer.
But a direct answer to your question is no~
Thomas
Safety Liner MVP
USMCRockinRV is offline   Reply With Quote
Old 08-14-2015, 11:09 PM   #3
Engine: GMC
Rated Cap: 42
It depends on what you mean by "efficient". It is cheaper to tint your windows and it is not too hard to do. On the other hand people can see into your bus at night if you have lights on and if you have no curtains. Tinting keeps out some solar radiated heat but has no insulating value. It all depends on what you want to do with your bus.
JA Savage is offline   Reply With Quote
Old 08-14-2015, 11:47 PM   #4
If you are referring to thermal blocking efficiency...negative. Not even close. As noted above. that requires actual insulation
Old 08-15-2015, 12:33 PM   #5
Engine: 190hp 5.9 Cummins
And bubble wrap is crap.
Real 1.5 inch rigid Styrofoam should be the minimum.
Old 08-16-2015, 12:37 AM   #6
Engine: 12V Cummins
Rated Cap: 75
Question...
Use Bubble Foil... Not Bubble Wrap.
USMC
Thomas
Safety Liner MVP
Old 08-16-2015, 12:44 AM   #7
Engine: 12V Cummins
Rated Cap: 75
Question...
I use Solar Screen and Bubble Foil on my front windshield when I park and it's the most amazing most wonderful most efficient most incredible most out performing and simple application to block 100% of the heat transfer...
In the rear I use Foam Board - I've shoved it up my emergency exit hole and it still transfers heat... I'll add bubble foil soon and eliminate the heat transfer completely~
USMC
Thomas
Safety Liner MVP
Old 08-16-2015, 01:21 AM   #8
Bubble foil is fine for windows that are still used, but is in no way a substitute for real rigid foam insulation.
All this talk of radiant this, and radiant that is snake oil. Just like the paint on insulation's.
There is simply no radiant anything that replaces the real Styrofoam insulation.
I only post this to keep the newbies from thinking they can just line the inside of their bus with reflex, VS real insulation.
Old 08-17-2015, 06:14 AM   #9
Coachwork: ward
Chassis: international
Engine: dt360a
reflective foil cracked my windshield!
Old 08-17-2015, 09:17 AM   #10
I've heard of truckers having that problem with the Reflectix in their windshields if it is tight fitting. It reflects back so much sunlight that the trapped heat buildup between it and the glass can create outrageous temperatures. Enough to shatter the glass.
Might make a handy Solar Oven though. Just toss some wienies and taters in there and use that heat.
Old 08-17-2015, 09:39 AM   #11
Engine: 12V Cummins
Rated Cap: 75
Haha... I've used the dash stove in Midland / Odessa plenty.
Thomas
Safety Liner MVP
