Old 11-20-2007, 04:37 AM   #21
Re: Question about a rear deck
My diagram didn't quite work out. Angles are inverted, with one flange on top of lower frame flange.
Brad Davis
79 International Wayne
"Big Blue"
bdavis441 is offline   Reply With Quote
Old 03-03-2008, 10:58 AM   #22
phillbus914's Avatar
Originally Posted by CaptJager
Not alot of discussion in the winter months. Trying to figure out if I should just buy a 7x14 inclosed for my Harley and 4 wheeler or if a rear deck would work. Thinking of this for a 95 international halfbus... would really only need on or the other not both at once bust still dyna wide glide is longer than my bus is wide.7.5 interior. could deal with that but 2500 and having it out of the salt of northern WI doesnt sound bad ...
Well I have a rack on my bus and it does work - I've hauled my Yamaha Raptor well over 1,000 miles on it with no problems. I would rather have a trailer hitch on my bus though. For one thing it's easier to load a trailer than a rack that's 4 feet off the ground. Another drawback of my rack is it's weight. I've never sat it on a scale but it's gotta weigh around 300 lbs. I can't move it around by myself and installing it takes at least 3 people. It's a huge pain in the ass.
I'd recommend going with the trailer.
My Old Bus :(
Old 08-15-2008, 03:16 AM   #23
Coachwork: Cavalier
Engine: 4Cyl
Rated Cap: 5
These are pretty good. I've seen a bus where they cut part of the backend, and welded making it into a truckbed. Here's a mockup. Try to ignore the front end, as there was a car blocking it in the original picture. I think the one I seen had a bed as long as 3 or 4 windows though. Any ideas on how to do this cost effectively, and without much difficulty?
Raditude is offline   Reply With Quote
Old 08-15-2008, 09:21 AM   #24
Rad your going to be pretty handy to have around here.
Abbott is offline   Reply With Quote
Old 08-15-2008, 06:23 PM   #25
Originally Posted by Smitty
I dunno Abbott....the front wheel already fell off the bus Just skiddin'
Old 08-18-2008, 06:37 AM   #26
Coachwork: Cavalier
Engine: 4Cyl
Rated Cap: 5
Thanks
lol
Cost would be minimal (blades & welding supplies mostly), know-how ....priceless Deciding where/how to cut, as well as making a good clean/straight cut will save alot of work. I'd ad a 1/5"-2" or so backing strip (of similar gauge as the body is constructed from) inside the bus around the entire cut for strength, as opposed to a mere butt-weld. Weld the outside of the body & grind clean, add mud where necessary.
Smitty
Thanks a lot.
adding rear deck gbstewart Conversion General Discussions 13 10-02-2016 01:05 PM
REAR DECK bansil Conversion General Discussions 4 11-19-2012 09:11 PM
how long is your rear deck? gbstewart Conversion General Discussions 1 05-26-2011 09:39 AM
Someone, somewhere wanted pics of my rear deck. crazycal Skoolie Conversion Projects 4 12-14-2008 12:05 PM
Rear Deck on Bus... aceinthehole2220 Skoolie Conversion Projects 7 07-30-2008 10:49 PM
