Old 05-30-2019, 05:28 AM   #1
Question about extended stop sign removal
In order to take some photos of my bus for my insurance company, I removed the two extending stop signs from the side of my bus. To do this I simply clipped the wires leading to them.
My battery has been dead for a couple of weeks, but now that I (finally!) have my title, registration and insurance all in order, I'm going to attempt to recharge the battery and take my bus for a drive. Are the clipped wires to the stop signs going to prevent my bus from starting? If so, are there specific wires in the remaining cable that I need to short out to get the bus starting again?
I don't have a computer or Internet access where my bus is (40 minute drive away) so I'm trying to get all my ducks in a row before I head up there.
Old 05-30-2019, 05:35 AM   #2
The stop sign wiring shouldn't be hot unless you hit the switch. You can check it with a multimeter real quick though.
Old 12-26-2021, 01:21 PM   #3
Coachwork: Worthington
Engine: V8 diesel
Rated Cap: 26,600
Hello I have the same issue was told I had to remove the stop sign on my 2004 IC school bus I cut the wires in bolted the stop sign now all It does when I put key in ignition and try to start is loud buzzing engine won't turn over . Before I did this she started just fine ? Any ideas or solutions ?
Jonby2 is offline   Reply With Quote
