Old 12-28-2010, 06:08 PM   #1
Ob1
Year: 1963
Coachwork: Grumman
Chassis: Chevrolet
Engine: Chevy 292 I-6
Re: Question about inverter/Charger with generator
As long each power source {shore, generator, inverter} has a separate input into the breaker box, you will only be limited by each sources ability. You DO NOT want to be able to have more than one power input at ANY time! On my rig it is a simply done by having a single inlet to the breaker box, selecting the input power source by plugging it in and having no second inlet for duplication.
You have to limit your power use based on the input, and that is based on the wattage or amperage you use. My rig, I can run everything on my generator and of course shore power. When I get my battery bank set up, I should be able to run everything but the A/C parked, and should be able to run that when the engine is running.
Ob1 is offline   Reply With Quote
Old 12-29-2010, 06:36 PM   #2
Year: 89
Coachwork: thomas
Engine: 7.3 diesel
please explain how you are going to power the a/c when going down the road, just interested
see my conversion at https://www.skoolie.net/gallery/v/Skoolies/Putters+Bus/
putterspitt is offline   Reply With Quote
Old 12-30-2010, 06:05 PM   #3
Ob1
Year: 1963
Coachwork: Grumman
Chassis: Chevrolet
Right now I do it by running the generator. When the battery bank is done, and the high amp alternator is installed, my 3KW {4.5KW surge} inverter may be up to the task, hasnt bothered my 3.5KW generator.
To the OP; I dont know how you will be able to separate the different circuits within the same breaker box to keep from crossing power sources. I suggest you run a single breaker box, with a single inlet, and be able to plug your various power sources into that inlet ONE at a time. From there, only use the appliances that you know the particular power source will handle.
Old 12-30-2010, 10:24 PM   #4
Originally Posted by TheStebes
Thanks for the reply.
This image helped clear things up: http://www.marxrv.com/12volt/inv3.gif
Basically, I'll keep appliances like the microwave/ac unit on separate breakers which are only tied to the AC input from the generator. . . .
The drawing linked to was for 120 volts single-phase. It was drawn as a special box with a split main leg. By using a common 240-volt panel for a 120-volt system, breakers on one 120-volt hot leg could be wired to the shore/genny input, and feed the charger/transfer switch input of the inverter/charger plus heavy loads like the air conditioner. The other set of breakers would be the critical loads side fed from the inverter output. The inverter output would feed back through one large breaker on that leg as the sub-master. The two legs would not be tied together, except through the inverter when on live shore/genny power.
A more common set up I've seen in commercial buildings and also in RVs is to have two breaker panels - one street panel plus an 'emergency' panel for protected loads. Using the split 240-volt arrangement instead of another panel means you should have optional connector buss bars installed in the panel as shown in the drawing in the link. One bar is bonded to the enclosure for the safety grounds, another one isolated from ground ties together the street-fed neutrals, and a third isolated from the other two for the inverter-fed neutrals. The grounds can be tied together, but the neutrals should not be bonded to ground except at the sources: the campground/house entry point, inside the genny, and in the internal inverter transfer switch. Get an RV-model inverter with a 3-pole internal transfer switch for hot, neutral, and ground; not a residential model with two-pole transfer that only switches hot and neutral.
Of course, the KISS method of having the breaker box fed from a plug that is moved to different outlets fed by street, genny, or inverter avoids most problems, outside of remembering not to run air conditioning or other heavy loads off of the inverter. But you lose the automatic power failure transfer feature for critical loads such as medical equipment, refrigeration, etc. It may be OK if the AC quits if the genny runs out of fuel, but your companion(s) may get testy if the TV also quits during a favorite show while you are out wrestling with the tanks. The same would hold true of a power failure while sleeping with a "hose to the nose."
Is there a Charger/inverter/distribution combo? rex_1_mn Conversion General Discussions 6 12-09-2012 01:05 PM
new inverter/generator gbstewart Conversion General Discussions 3 12-17-2010 01:42 PM
Inverter/charger/monitoring systems BUSBOZO Conversion General Discussions 1 02-26-2010 07:23 PM
Generator vs Battery w/Inverter arfisher83 Everything Else | General Skoolie Discussions 1 01-20-2009 03:33 PM
an other Inverter/charger question swinada Conversion General Discussions 6 07-30-2007 02:16 PM
