Old 08-10-2008, 06:43 PM   #1
Re: Question about rear bed position
I thought about this over and over for a few months myself. With a front engine bus the solution I came up with was a bunk on each side of the aisle in the back bedroom. Which will leave the center aisle of the bus open from the front stairwell to the back door and the back door clear when needed. I plan to add a small ledger onto the aisle-side of each bunk that will support a piece of plywood that will set down onto the ledgers on both sides. Thus providing a nice large bed in the back for use when I don't mind the rear door being mostly blocked. My wife and I could still readily open the back door and move outside if needed. When not in use the extra sheet of plywood will be stored under the mattress of one of the bunks and the extra mattress pad could be stored on another of the racks (bunk beds) or back bunks as well.
Abbott is offline   Reply With Quote
Old 08-10-2008, 08:31 PM   #2
GoneCamping's Avatar
During my initial search phase, I had made some rough idea's on what I'd do if I had a front engine bus with a rear E-Door on it. My plan was wall the rear area off about 18-24" from the end of the bus, and use the back end with the door as a "Garage Storage" area... I'd probaby have made some kind of trap door in the wall so I could Emergency exit out the back still...that was if I couldn't find one with a side door too.
Since I wound up with a transit style bus that became a moot point, but then I had to build cargo storage underneath, the rear door would have been easier!!
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 08-12-2008, 05:37 PM   #3
Xtevan's Avatar
Coachwork: BLUEBIRD
I had my queen size bed attached to the left wall with a small aisle on the right. I have taken it off and cut it in half and reframed it with hinges in the center. It will attach back to the left wall with more hinges so it can fold up flush to the wall/windows and bungee cord out of the way for motorcycles or big loads to burning man. I plan to find a foam mattress that I can cut in half at some point and use it half folded as a coach.
When I get it done this weekend I will try to take a few pictures and post on my conversion thread here.
Xtevan
Bus Project Pictures
http://picasaweb.google.com/XtevanofthePlaya
Xtevan is offline   Reply With Quote
Old 08-12-2008, 09:36 PM   #4
James P's Avatar
Year: 1968
Chassis: B602
Rated Cap: 58
Send a message via AIM to James P Send a message via MSN to James P
Damn i love that idea! I might just have to use it!
My Skoolie project at http://www.trolleybus.ca/bus
James P is offline   Reply With Quote
Old 08-13-2008, 09:30 AM   #5
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
I kept the rear side door (was a wheelchair door) accessible with the plan of using it as a part time entry/exit...but honestly it just doesn't happen. The opening is only about 4' high, so regular use would require wearing a helmet. I only keep it accessible and functional as an emergency exit.
Sean
Bus conversion/info here
SeanF is offline   Reply With Quote
Camp hosting position, Port Townsend, WA lornaschinske Everything Else | General Skoolie Discussions 2 12-09-2011 12:44 PM
Pedal position question PDBreske Conversion General Discussions 1 08-25-2011 11:02 PM
Question about a rear deck phillbus914 Conversion General Discussions 25 08-18-2008 07:37 AM
SOLD: Paneltronics 6-Position Lighted Rocker Switch P SeanF Classifieds | Buy, Sell, Swap 2 07-09-2008 09:27 PM
Question for you rear engine guys the_experience03 Everything Else | General Skoolie Discussions 5 12-10-2006 04:19 AM
