Old 06-15-2019, 09:50 AM   #1
Question about rivet spacing
I have 7" diameter circular steel plates, 1/8" thick. I am using them to cover the holes left by removing the flasher lights. I am going to be riveting them in place with 1/4" steel pop rivets. Should I use 8 total rivets around the circumference or 12? Is there some sort of handy rule for the ideal spacing between rivets?
Also, I've found that in order to drill holes that my 1/4" rivets will fit into, I need to use a 17/64" drill bit (1/4" holes don't seem to fit the rivets even after de-burring). Is this normal and expected, or should I use a 1/4" bit and hammer the rivets in?
Old 06-15-2019, 11:27 AM   #2
If they are 1/4" rivets, use a 1/4" drill, any bigger weakens the connection.
Old 06-15-2019, 11:30 AM   #3
+1
I had to use a hammer to gently tap my rivets in on over half of them.
Old 06-15-2019, 12:20 PM   #4
Hmm, this source: https://www.fastenermart.com/underst...nd-rivets.html
... says a 1/4" rivet needs a hole 0.257 - 0.261 inches in diameter, suggesting my 17/64" (0.2656) bit is too large but a 1/4" bit would be too small.
Aha, same table mentions an "F" bit. I've never heard these letter-designated bit sizes before, but that's apparently what I need. Yay, I already messed up one of my plates! Good thing they weren't too expensive.
Old 06-15-2019, 02:25 PM   #5
Sleddgracer's Avatar
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
l've used a 17/64 for 1/4" rivets in other applications and it worked fine - no problems later on
Old 06-15-2019, 03:04 PM   #6
I did some experiments on doing waterproof patches using the 17/64" for 1/4" rivets. All the rivets leaked a small amount and required Dynatron-550 sealant to be watertight. I wonder if they would leak less or not at all if the rivets were a tighter fit with the holes (seems obvious but you never know).
I just ordered a bunch of cobalt F bits from Amazon, after wasting an afternoon driving to Blowe's and Home Repo to learn they don't carry them.
