Old 12-27-2008, 08:52 PM   #11
Engine: 7.3 diesel
Re: QUESTION: Skoolie Alternative.. FIRE TRUCK ??
Showing one firetruck from the show that does run and move but that guy just don't do it from my understanding. But you can not forget about the other one on the show but it wasn't a regular firetruck like most of us are used to seeing. See linky below
http://videos.howstuffworks.com/discove ... -video.htm
Also web site with use firetrucks
http://www.ericksontrucks.com/
Old 01-02-2009, 06:24 PM   #12
oldog12's Avatar
If you're interested... Bus Conversions Magazine is supposed to do an article on a converted fire truck next month
oldog12 is offline   Reply With Quote
Old 01-02-2009, 07:31 PM   #13
there is a Bus Conversions Magazine? how did i miss this?
cucullen is offline   Reply With Quote
Old 01-03-2009, 08:39 AM   #14
oldog12's Avatar
They mostly deal with coaches... you know, like MCI, Prevost, etc., etc., etc.....
Old 01-07-2009, 06:27 PM   #15
Coachwork: Ward Genesis
Engine: DT466/MT643
20K miles for a 20 year old truck sounds about right. However, keep in mind that fire truck miles are like dog years! Also, many older fire trucks don't go very fast...55 or 60 might be top speed. One more thing is that a fire engine is designed to pump water while parked. So it may have a ton of hours compared to the miles it has driven. Fully loaded with water a truck from the 80's or earlier might not even be able to hit 55 mph.
One of the tankers here is an old Diamond-REO 5-ton Army truck...it will barely hit 55 empty. It's definitely bringing up the rear when the tank is full.
The ladder trucks will sail up hills with the cars, though...pouring black smoke, and with the 12V71 Jimmy in Ladder 12 drowning out the siren spinning 2500RPM through its 5" straightpipes. It's been overhauled and, uhh, turned up a little. (It's about 600HP according to one of the deputy chiefs.) Ladder 8 isn't quite as crazy, but its turbocharged 855 Cummins Big Cam is turned up pretty high (500HP, maybe). One of the volunteers is a retired truck mechanic & he overhauled them.
Both have finally had their duplex 15-speeds replaced with 13-speed Road Rangers in a nod to the fact that only three guys--none younger than 60--could drive them. They also got power steering (air-assist) around 1995, and Ladder 8 got big super single tires in front. (It got those before the power steering, which is something I do not even want to think about in a tight parking lot.)
Amazingly, the only automatic transmissions in the entire FD are the ambulances.
Jarlaxle
New to Skoolie... Question about CNG? inspireout Conversion General Discussions 6 12-13-2014 07:17 AM
Skoolie Newbie Question alaskalimousine Conversion General Discussions 7 01-15-2014 08:26 PM
Towing a 4x4 truck (small truck) 4 down Abbott Everything Else | General Skoolie Discussions 13 12-31-2009 02:05 AM
Question about Aluminum paint vs. GM truck pewter vs GREY lapeer20m Conversion General Discussions 1 03-17-2009 10:09 AM
Truck doors on a skoolie? Michael Merbach Conversion Tutorials and How-to's 1 09-24-2008 09:26 PM
