Old 06-25-2006, 01:06 AM   #1
wtd
wtd's Avatar
Year: 1982
Coachwork: Thomas TransitLiner
I tapped my brake system, just took out the drain valve, put in a tee and put the drain valve back on the end. Came off the tee with a hose barb and stuck on a plain old air hose. I put a valve in there also, in case there's a leak or other problem I can just turn it off and still have brakes.
The tank on the left(rear, lower picture) has the tap, the tank on the right(front, lower picture) is original. I have 4 tanks and tapped the one closest to the compressor. Put a water trap/filter/regulator on the line, a $20 deal from Harbor Freight on sale. Funny, just noticed that the drain valve is upside down on the right tank ...
I painted a few things with this, including the ceiling and some outside parts and it seems to work fine if you have patience. I had no other need for a compressor, so this was OK with me. It seems to work a little better if you get one of those air tanks that are made to fill up at the gas station and bring home, and put it on the line. I put a 5 gallon tank on there and didn't have to wait for the compressor to catch up so much.
Don't know about the sign thing, I don't have any of that, but don't know why you couldn't ....
Tom
The Rolling Motel Room
Where DIY meets WTF
wtd is offline   Reply With Quote
Old 06-26-2006, 03:21 PM   #2
Sounds like you have vaccum assist brakes, not air brakes. Those are vaccum cannisters.
Brad Davis
79 International Wayne
"Big Blue"
bdavis441 is offline   Reply With Quote
Old 06-26-2006, 11:24 PM   #3
lapeer20m's Avatar
slightly off topic....ok, completly off topic of painting, but keepig with the topic of brakes.....
where does the power come from in the hydraulic brake system with a diesel engine? I have hydraulic brakes, and I know that the electric "hydraboost" system kicks in when the engine is off and you use the brakes. Where does the force come from when the hydraboost is not operating? (which is mostof the time?) There is no vaccume like you would have on a gasser.
Painting...here we go! opus Conversion General Discussions 3 05-13-2011 09:35 AM
Painting Questions madpsalmer Conversion General Discussions 4 10-27-2010 03:40 PM
Painting bus putterspitt Conversion General Discussions 12 10-05-2010 08:54 PM
I need painting help Frank ZX Conversion Tutorials and How-to's 1 08-15-2009 07:34 AM
Painting your Bus kirkndopp Conversion General Discussions 3 06-20-2009 09:26 AM
