Old 07-25-2013, 12:37 PM   #1
Hex
Hex's Avatar
Coachwork: Bluebird, Model 3800
Rated Cap: 42
Quick DC Electrical Question
Hey, I'm thinking I'm going to go for my house batteries and wiring as my next big investment, so I'm thinking about my DC wiring.
I'm just wondering how people have closed their loops for DC outlets and lights that they've put in. Do you ground to the frame/skin and then just connect the negative on the house battery to that as well? Or do you run a full return line back to the battery?
Thanks!
Hex is offline   Reply With Quote
Old 07-25-2013, 12:45 PM   #2
roach711's Avatar
Rated Cap: 19
Re: Quick DC Electrical Question
My bus has a fiberglass body so I had to ground all my wiring runs back at the battery box, but with a schoolie's steel body you can ground right at the fixture saving a lot of wire. I use dielectric grease (available wherever electric supplies are sold) on all my ground connections to avoid corrosion. Not strictly necessary, but may save some circuit chasing later.
The Roach Motel
Old 07-25-2013, 12:56 PM   #3
JakeC's Avatar
Just grounded everything to the body. No issues whatsoever.
Brutus
Old 07-25-2013, 01:27 PM   #4
Hex
Hex's Avatar
Rated Cap: 42
Thanks. And you just run the negative pole of the battery back to the body? Awesome.
Cuts the cost of my wiring in half ... ;)
Old 07-25-2013, 01:41 PM   #5
lornaschinske's Avatar
Rated Cap: 89
If you look at your starter battery, find the ground wire and trace it back to where it termintes. Ours terminates on the chassis. We grounded our DC to either the steel body or the steel frame with the frame being the preferred ground.
Fulltime since 2006
Old 07-25-2013, 01:57 PM   #6
I would make sure and have a good heavy wire between the frame and the body...incase the body is really isolated good with rubber
Will help the electrical path when it can go straight from the body thru strap and to battery
like these
or at least this
Old 07-25-2013, 02:08 PM   #7
Rated Cap: 89
Okay, forgot to mention that it needs a very good, bare metal connection.
How dat?
Fulltime since 2006
Question about electrical panel SitkaConvert Short-Bus Conversion Projects 4 08-27-2014 02:21 PM
Just starting: electrical system question BelltownBikes Electrical, Charging and Solar 10 03-18-2013 03:36 PM
Electrical question Redbear Conversion General Discussions 4 07-23-2010 08:09 AM
General electrical question putterspitt Conversion General Discussions 6 06-07-2010 02:29 AM
Electrical - wiring Question swinada Conversion General Discussions 11 05-25-2008 04:04 PM
