Old 05-05-2016, 12:42 PM   #11
Rated Cap: Your mom +1
Just go ahead and do the raise if funds allow. The hardest thing about raising mine was shelling out the cash for the materials (mostly the steel sheeting)... I'd rather spend a few bucks and have a weeks worth of work than have a stiff neck and walk around like a hunchback all the time... But, Ill be living in mine full time too so take that into consideration...
Old 05-05-2016, 02:58 PM   #12
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Roll Your Own Build Thread
Old 05-05-2016, 05:11 PM   #13
Robin97396's Avatar
Originally Posted by family wagon View Post
The clearance in my bus vs my height led to feeling my hair brush the ceiling sometimes, especially when walking at a quick pace down the aisle. I had a really hard time suppressing the reflex to tilt my head sideways to duck down a little bit. If I spent much time in the bus it resulted in a sore neck that could take a while to clear up. I knew I'd be losing some height to insulation, too.
Between those and really wanting to make 3-level bunk beds to reduce the floor footprint of sleeping areas, I decided I'd have to overcome my concerns and just do the raise.
Isn't it obvious? You just need a haircut.
Old 05-05-2016, 07:39 PM   #14
Chassis: Blue Bird
Engine: ISC 8.3
Well shoot, I completely overlooked that solution! Woulda saved me LOTS of time and money!
Could you persuade my kids that when we're on road trips, being "tucked in" at night without a roof raise means lying down in a shallow drawer and the drawer then slid into the rack for the night -- and that just as soon as they fall asleep, they'll forget all about the fact that there's not even enough height to turn over? I promise I'll pull the bed-drawers back out in the morning. Some time.
Old 05-05-2016, 08:12 PM   #15
Robin97396's Avatar
Yeah, I'd make em sleep with seatbelts on too.
Old 05-06-2016, 05:25 AM   #16
Year: 98
Chassis: D
Engine: 7.2L turbo Cat C7 3126
I think a roof raise is totally worth it if you are going to be spending much time inside the bus. It is a LOT of work, and it mine cost about $400 (sheet metal, insulation, glue, screws, rivets, wood supports, metal beams) but there is so much more space now. Not only does this create more usable space, it also makes the a huge difference in the 'feel' of the bus.
I should note that I did not raise the entire roof, I left the front and back unraised and just built on top of them. This way I got more usable space (sq footage) and I got the vaulted ceilings that are more comfortable. I figure the cramped feeling in the unraised sections will be offset by the openess in the center.
You can see photos of my build on my blog:
TheBigBusTheory.wordpress.com
gobygoby is offline   Reply With Quote
Old 05-06-2016, 05:41 AM   #17
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
im 6', i looked for a bus with a 78" ceiling. so much easier.
my build pics
Old 05-06-2016, 07:33 AM   #18
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
Originally Posted by Robin97396 View Post
You must have had cold feet during the winter.
I like being comfortable, and the house I'm renting now has crap fiberglass insulation (that the landlord isn't planning on replacing) and the linoleum in the kitchen and bathrooms glued directly to the OSB subfloor.
Captain Obvious on deviantArt
Old 05-06-2016, 09:55 AM   #19
Robin97396's Avatar
In alaska I had a landlord that would turn off the heat during the day in mid winter to save money. This was in winter and it became obvious when I could see my breath inside the apartment one day when I stayed home sick. Then after leaving for a few hours I came back and my coffee was actually icy on top.
Never could rectify the situation with the landlord and eventually moved.
