Old 03-11-2018, 01:23 PM   #1
Raising the roof by lowering the floor?
Hey guys,
I've been watching a lot of conversion videos online and the weapon of choice seems to be to raise the roof to gain more head room. I was wondering if anyone has cut into/lowered the floor of a skoolie and if there are any other hurdles associated with that- be it law or simple automotive logistics. Thanks a bunch!
The Fox
zQwkBrwnFox is offline   Reply With Quote
Old 03-11-2018, 02:32 PM   #2
Chassis: Saf-T-Liner MVP ER
Originally Posted by zQwkBrwnFox View Post
Hey guys,
The Fox
Directly below the floor are cross-members that sit on the chassis rails. The body is bolted to the chassis with plates.
Neat idea, but it isn't going to happen.
Steve Bracken
Build Thread
Old 03-11-2018, 05:06 PM   #3
Jdawgsfanasty's Avatar
Hey guys,
The Fox
As twigg said...nope...I've thought about insulating the space created by the ribs in the floor panels...Idk...I ain't got my skoolie yet
Jdawgsfanasty is offline   Reply With Quote
Old 03-11-2018, 05:47 PM   #4
joeblack5's Avatar
Year: 98
Hi Fox,
Not sure what kind of bus you have. But that is my plan on our Elf bus( E350 van chassis) It has aluminum floor ribs and I would be helped with a partial galley ( bowling alley) in the middle. That will help with better view through the windows and also keeping the original structure intact. ( I know , a lot of opinions on that on this forum)
My floor ribs are channels on its side and it will not be hard to make a 3/4" aluminum reinforcement so that the center section can be lowered.
In my chassis I have only 4" of room to drop between the frame rails before I hit other parts. But it will be a valuable 4" for me at least.
Good luck , later J
Old 03-11-2018, 06:17 PM   #5
Originally Posted by joeblack5 View Post
Hi Fox,
Good luck , later J
Hey Joe Black,
Thanks so much for sharing! I was curious if anyone had tried or was going to try. I haven't gotten a bus yet, the Missus and I are still looking and planning a lot of things, but finding a way to utilize the empty space I've found under skoolies has captured my imagination and if getting under there is actually possible.
Your aluminum reinforcement. Are you welding it to the frame?
Old 03-11-2018, 06:43 PM   #6
joeblack5's Avatar
Year: 98
No. I will bolt it. I will cut some of the ribs just inside the frame rails. I will use a water jet to cut 3/4 Alu sheet in Z shape so that the top of the Z fits snug about 6" inside the ribs. The lowered rib and floor will fit snug in the lower part of the Z , so two Z's per rib.
I used to live in a VanHool city bus with a walking alley in the middle. The seating, tables and so were on the sides. A little step up was not a problem for us but having standing height and better vision is a big plus.
The E350 is going to be converted to 4x4 and so I do not want to loose structural strength messing with the roof. I also do not want to increase the bus height in regards to tip over and top heaviness. Lowering the floor lowers the center of gravity , at least on paper.
The cut alumium Z will extend of the frame rails and will be actually stronger than the unmolested rib channel.
later j
Old 03-11-2018, 08:01 PM   #7
Anything is possible with a little thought and deep pockets.
Old 03-11-2018, 08:07 PM   #8
joeblack5's Avatar
Year: 98
That is for sure but I do not think that this floor lowering( in my case) would cost more then $200 in material.
For the 4x4 ,.... I have all the parts, actually the whole 4x4 ambulance van. It used to be our expedetion vehicle before I blew the 7.3 engine head gasket. Bought that for $ 1900 7 years ago. So that part is almost only time. Time is free .
later J
Old 03-11-2018, 08:08 PM   #9
later J
Material may be cheap, labor will be quite intensive.
Old 03-11-2018, 09:26 PM   #10
All the Power to you Joe.
floors, head room, roof raise, space-saving
