Originally Posted by Tango
Personally...I won't apply anything that contains water to bare metal, regardless of any product claims. Only oil or epoxy based. After that, you can go directly to final finish..or...if more build up is beneficial, use a high build primer...then the final.
Don't use epoxy unless you are 1. going to apply your top coat within 7 days or 2. plan on re applying epoxy before paint.
Real epoxy primer is not sandable and has not chemical bond after 7 days so your paint won't stick to it unless you re apply the primer.
I just primed using a DTM (direct to metal) primer, Urethane/ epoxy mix that is sandable. The brand I went with is SEM "metalock" its a 2k 4:1:1 primer:hardener:thinner
I don't think you will have any luck "sanding" that Henry's off, I me pretty sure you can steam it and use a putty knife though.
The bigger issue i see is you using sheet metal screws, replace them with pop rivets and you won't be giving people flat tires... A cheap pneumatic rivet gun can be had from Hearbougher fright and will keep you from getting carpal tunnel or the dreaded "claw" and after 960 rivets my hand feels fine
