Old 01-01-2014, 08:05 PM   #1
Year: 87
Chassis: International s1700
Engine: 6.9 internatiional
Range hood wiring diagram
Hi folks,
for the life of me i cant find the wiring diagram for a Range hood. it has 7 wires on the harness, and im sure some of the wires are for tank sensors etc. if you guys have any ideas what each of these wires do i would be grateful.
thanks
Eric
proconsul100 is offline   Reply With Quote
Old 01-03-2014, 06:25 PM   #2
Re: Range hood wiring diagram
Unless someone has the same exact unit as you, a photo of the connector probably won't help. Time for some detective work. If you could advise whether the fan and light are 12 VDC or 120 VAC, that would be a start. To really get an answer, you need to either measure the wires with a meter, or open up the hood and get a photo of where the colored wires attach to the panel or sub-assemblies.
I will assume for a minute that you have 12 VDC fan and light. I expect there are the following wires:
+12 VDC battery hot for everything, probably including the battery meter
- 12 VDC ground for at least the fan, light and gauges
Switched +12 VDC out to run the water pump
input from sensor for the water tank
input from sensor for the grey tank
input from sensor for the black tank
That is six out of seven. I expect the seventh might be a switched ground for the water pump. It could also be reference for the tank sensors instead of using the vehicle chassis or batteries. Or it could be an independent battery wire for the voltmeter, to get a more honest reading direct from the battery, without the "IR" voltage drop due to current being drawn on a wire shared with the light(s), fan, and water pump.
You can't trust the colors, because automotive practice uses red for positive and black for negative, while RVs often use trailer colors which match house wiring - black for positive and white for negative. The battery positive and negative could follow either system, or its own.
The thickness of the wires is a clue - if there are larger and smaller wires, the high current wires that power everything would be larger, and the low current wires that sample the three tanks would be smaller.
If I were a betting man (which I am not), I would guess that the three wires in the foreground look smaller, and might be the tank meters. I would pick the red and black as battery wires, and the white and yellow as switched pump wires.
But you should be able to figure this out for yourself.
If you open the case for inspection, the ground wire should go directly to the fan, light socket(s), and the indicator board. It may also go to the pump switch if the switch has 4 wires.
The battery wire should go the to fan switch, the light switch, and the pump switch. It should also power the indicator board, either direct, or through the monitor switch first, so the board is only live when the switch is on. I would not be surprised if the switch is spring-loaded, so that you have to hold it to check the tank levels.
The three tank indicator wires should go directly to the indicator board.
Any switched hot wire out to the water pump should go ONLY to the pump switch.
The seventh wire may be a switched pump ground in addition to a switched hot, so an RV manufacturer could wire the pump multiple ways. If so, there will be 4 wires on the pump switch. A pump could be wired always grounded with a switched hot, always hot with a switched ground, and with both hot and ground switched for extra safety.
If you know how to use an ohmmeter, you should be able to get the fan, light, and pump figured out without opening up the hood, as long as you can get the light bulbs out of their sockets.
1. remove the light bulbs, so no false ohmmeter readings pass through the filaments
2. turn all the switches off, especially the fan for the same reason
3. measure from the threads or side of one of the light sockets, and find the wire that reads zero ohms, or pretty close to it. This would be the ground.
- It is possible that incandescent bulbs would be in series for lower light but almost unlimited life. If there is more that one light socket, and the first one has no ground, try the other one.
4. turn on only the light switch. measure from the button in the bottom of a light socket to find zero ohms to another wire. When you find it, flip the switch on and off a few times to confirm it is correct. This would be the battery wire.
5. once you find the battery wire, turn the light switch off and the water pump switch on, and find another wire that connects to the battery wire with nearly zero ohms. When you find it, flip the switch on and off a few times to confirm it is correct. This would be the water pump hot wire.
6. repeat step 5 between the ground and the unknown wires, to see if there is a switched pump ground
Unless there is a lot of stray paths through the battery condition meter on the circuit board, this method should have the basic 3 or 4 connections covered to use the fan, light(s), and water pump control.
Old 01-04-2014, 11:12 AM   #3
Year: 87
Thanks Redbear, you gave me some great information here. I think i will get out my meter and ohm out some of the connections. you are correct about the wire size differences. i have taken a picture and separated the wires into their 3 different size groups the middle red and yellow are the largest, black and white to the left are the middle size and small red, brown and Grey are to the right in this picture:
thanks
Eric
Old 01-04-2014, 05:20 PM   #4
turf's Avatar
i feel smarter for having read that
Turfmobile Build Thread
Old 01-05-2014, 09:02 AM   #5
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Is it not possible to simply open the panel and see where the wires go?
Old 01-05-2014, 09:50 PM   #6
Year: 87
i want to, but i am afraid of breaking the panel, as i cant see how it is attached, thats why i was looking for someone who might have this hood. im going to try ohm-ing it out first, last resort will be to pry the plastic panel off.
Old 01-18-2014, 08:18 PM   #7
Year: 87
i removed the front panel and i am examining it now. the connector on the left is for the fan and light so i know i can get those 2 working.
Old 01-19-2014, 10:31 PM   #8
My analysis:
The external black goes to the fan switch, the light switch and to the monitor switch - it is the hot.
The internal black goes from the monitor switch to the circuit board - it is the switched hot for the level gauges.
All the whites are spliced together - the fan, the light, and the circuit board - they are the grounds.
The red goes only to the water pump switch - it is a hot from a dedicated water pump fuse, so it can be separate from the range hood fuse.
The external yellow goes out to provide power the water pump.
The internal yellow provides power to the water the pump power on indicator on the monitor board.
The three small external wires are for the three tanks as previously guessed.
The empty pins in the middle of the circuit board connector are for the optional water heater and generator indicators.
It is a nifty way to have all your basic indicators at eye level. I think it's kind of cool.
Old 01-26-2014, 01:00 AM   #9
Year: 87
Originally Posted by Redbear
My analysis:
i checked this out with 12Vdc and a meter, and i believe you are correct. thanks for figuring this out Redbear.
Bluebird Wiring Diagram Tinez Everything Else | General Skoolie Discussions 3 05-25-2019 10:42 PM
Help: Need a wiring diagram bhays Alternative Fuels | Electric, Propane, Wood Gasification, etc. 8 03-09-2012 08:21 AM
Wiring Diagram El Mastodonte Conversion General Discussions 0 07-25-2010 12:45 PM
Range Hood GoneCamping Conversion General Discussions 2 07-26-2009 08:16 AM
Need wiring diagram or source for same frank-id Classifieds | Buy, Sell, Swap 1 11-18-2007 10:41 PM
