Old 03-04-2013, 10:40 AM   #1
Chassis: 42 Passenger
Engine: Chevy
Reality check - can I make it up hill?
We are converting a 28 foot "42 passenger" 1984 Bluebird into a burning man art car. We've almost completed an upper deck made of steel, 2x4's and 3/4" ply. The bus runs on propane.
As we plan for the rest of the conversion, we're starting to wonder if it's possible to make the bus so heavy that it won't make it over the hills. Can anyone offer some real-world perspective/experience?
Can someone with a similar powered vehicle share their curb weight post-conversion?
Prior to buying more lumber for the facade, we had the idea to throw lots of weight inside, go weigh the thing, and then drive over the biggest local hill.
Any other advice on planning for such a thing?
Thank you!
-Gano
http://theartcar.wordpress.com
gano is offline   Reply With Quote
Old 03-04-2013, 11:38 AM   #2
Re: Reality check - can I make it up hill?
This will be neat when done...cant help other wise except to say "Good luck" and maybe faux fiberglass tree trunks for wt and so they can be taken off to stay under width and ht laws?
Old 03-04-2013, 02:58 PM   #3
roach711's Avatar
Rated Cap: 19
Figure the weight of the seats you removed plus the weight of a full load of kids at 150# each. I bet you'd have to work at putting that much weight back in.
The Roach Motel
Old 03-04-2013, 03:08 PM   #4
Did you see the size of the trees?
Old 03-04-2013, 04:48 PM   #5
Engine: Chevy
Trees will be fiberglass.
We estimate that the steel we will have added will be 700 lbs.
And then we intend to cover the sides of the bus in resawn or plywood (very thin).
Old 03-04-2013, 06:07 PM   #6
Chassis: Tc2000
Engine: 5.9 Cummings turbo diesel
My BB weighs 18040 pounds dry and it is 40' long. I have 10 acres in east Texas. The front of the property is a STEEP hill. I put it in low and make it up fine. And that is loaded with 120 gallons of Diesel, 60 gallons of water, and all our stuff. Hope it helps.
Great nations rise and fall. The people go from bondage to spiritual truth, to great courage, to liberty, to abundance, to selfishness, to complacency, to apathy, to dependence, and back again to bondage.
kc_4_jc is offline   Reply With Quote
Old 03-04-2013, 06:15 PM   #7
91 Bus Guy's Avatar
Chassis: Chevy G30
Engine: 5.7 V8 TBI GM
Rated Cap: 10
Send a message via MSN to 91 Bus Guy
I like the idea you have for "The Tree House," can you share any more photos?
Now I am no expert, but the kids that bus was designed to haul adds up to over 3 tons.
Like roach711 said, I also think it would take a lot of art work to add up to the designed weight. I am looking forward to see more as you work on your project.
Good luck,
Keith
91 BG
91 Bus Guy is offline   Reply With Quote
Old 03-04-2013, 07:10 PM   #8
the_experience03's Avatar
You aren't going to stall the bus out going up a hill. However, if you are pulling up a long hill you might start to see temperatures rising. That would be my biggest fear. Making sure you have adequate airflow, swapping to synthetic fluids, radiator misters, and stopping to give it a break can all help.
Old 03-04-2013, 07:17 PM   #9
Oh.....and post some pics as she comes along.....you'll be fine wt wise; it seems
Old 03-04-2013, 07:18 PM   #10
weird double post
Old 03-07-2013, 12:52 AM   #11
thommassey's Avatar
Chassis: All American RE
Engine: 3208TA Cat 250HP
... always wondered what they figured per kid.
TUMBLEWEED (AKA Rufus) build:
viewtopic.php?f=9&t=11121
PICTURES : https://s1338.beta.photobucket.com/user/ ... M-HP/Rufus
thommassey is offline   Reply With Quote
Old 03-07-2013, 01:03 PM   #12
roach711's Avatar
Rated Cap: 19
I have no idea what the "official" average kid weight is; just figured that 150 would be a safe guess. Most kids are chubbier now than they were when I was in school so I'd bet that 150/kid is on the low side.
The Roach Motel
Old 03-07-2013, 01:51 PM   #13
Coachwork: Chevy
Chassis: Bluebird
Rated Cap: 16
It is very simple - go to a local junkyard or weight station and get your bus weighted. Then see what the GVWR is and you'll see how many pounds of people/belongings you can have in your bus. Another good gauge is how high the body rises when you remove stuff. I remember when the bus was bare we had a huge amount of space from the top of the tire when looking at the bus from the side. Now there is zero space . I went to a weight station though and weighted my bus without me in it. Found out I have 2 tons of weight I can bring on board. Plenty of weight!
Rutgers tailgating bus https://www.skoolie.net/forum/viewtopic.php?f=36&t=5545
RUskoolietailgater is offline   Reply With Quote
Old 03-07-2013, 09:18 PM   #14
Rated Cap: 47
42 passenger Chevy, must be basically what most would call a "two ton truck" or c6500 Chevrolet chassis. For some real world perspective, that same chassis would be rated for 10,000 lbs plus as a grain truck or flatbed. In that capacity, trucks get overloaded often. As a grain truck, people around where I live would routinely haul 15-18K.
Motobus is offline   Reply With Quote
Old 03-08-2013, 12:07 PM   #15
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
I'd give more priority to what happens on the downhill side of the grade. Going up, the worse that can happen is the engine overheats and seizes, blows up, etc. On the downhill side, the worse case scenario is being unable to slow down, and killing your self, your passengers or innocent bystanders.
There are techniques for safely descending steep & long grades; search here or the greater innerwebs. The technique involves selecting a lower gear (*before* the descent starts!) and a target speed, and maintaining the target speed with periodic braking.
I think you'll be well below GVWR, but it only takes a little time and money to get your bus weighed.
Good luck
Sean
Bus conversion/info here
SeanF is offline   Reply With Quote
Old 03-08-2013, 01:42 PM   #16
syke's Avatar
Sean speaks the truth. Watch the downhill side of life.
For 10 bucks or so you can run through a CAT scale at a truck stop. Then you can get axle weights also. It's nice information to have.
Ryan
Bluebird All American RE: Great White Buffalo (gone but not forgotten)
Our build thread: viewtopic.php?f=9&t=10065
syke is offline   Reply With Quote
Old 03-12-2013, 11:17 AM   #17
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
It's twuu, what happens going down is as important as going up. One thing that many overlook is the transmission. The temp rises dramatically going uphill. Make sure you check out all your systems before your trip or you might be on the news. Good luck with your build.
I'm hungry!
You Gotta Let Me Fly
Old 04-29-2013, 02:19 PM   #18
My camp did an art car conversion last year, Gracie Pleasure Barge. Check out our blog here: http://saltyjacks.wordpress.com/ and the bus's facebook page: https://www.facebook.com/gracie.saltybar?ref=ts&fref=ts
She's a 1974 built on a P30. Our camp is split between Seattle and San Fran. We did most of the structural work up here, and then drove it down to San Fran for decorating. I wasn't on the bus during her transportation, but she made it. Weight wasn't biggest issue for us, it was driving a 40 year old bus with unknown mechanical problems. It looks like you guys are in Victoria, yeah? I'd suggest signing up for AAA RV ultimate towing package, if you break down they'll tow you up to 200 miles in a calendar year. Keep a fire extinguisher in an easy to reach location, I heard about a guy who's bus's engine caught fire. When in doubt take the hills slow.
I bought a 2nd bus for our camp and I haven't started working on it yet, but I'm not going for an art-car. Just a fun party RV. Do you have any detailed information on your roof design? I'm debating moving to steel for a foundation but I don't know enough about metal working to make a good decision.
I can't wait to see this treehouse in action on the playa.
elmostan is offline   Reply With Quote
Old 04-29-2013, 04:22 PM   #19
lapeer20m's Avatar
I've driven a skoolie, some years grossly overloaded, from michigan to burningman and back 4 times.
I don't know where you live, but if you are heading west on I-80 towards the burn you never even need to use your brakes until you drop down into salt lake city. There are very few long hill climbs on I-80. There is always a low enough gear to climb a mountain. Going up is easy!
Heading back east, the climb out of salt lake city is epic in a skoolie! In my fastest bus i don't think we went over 25 mph on that climb, but neither did most of the big trucks.
If you have an auto trans, i've found that during hill climbing as the engine temperature climbs, so does the transmission temperature.
As far as going downhill in the mountains, i like to follow a big truck at a good safe distance (maybe a quarter mile.) If the truck goes 60 mph around a curve, you can too. If he slows down to 35 mph, you should too! That's the method I use for going down the mountains in a skoolie. Obviously if you have air brakes, you want to get out and physically check your brakes before descending. If you have hydro brakes, you want to make sure they are in good working order before leaving home, and also want to make sure that the backup electic/hydraulic system is functioning properly if so equipped.
Old 04-29-2013, 09:47 PM   #20
Chassis: International S1800
The downhills into SLC were the only time I was thinking about brakes on our skoolie trip. There are some serious downhill grades there, with turns, and lots of traffic.
thrash is offline   Reply With Quote
The impossible hill somewhereinusa Everything Else | General Skoolie Discussions 11 11-26-2012 07:00 PM
Two men make RV living hip Xtevan School Bus News 4 01-17-2010 07:48 PM
Propane injection ,extra horse power on a hill ? mike Alternative Fuels | Electric, Propane, Wood & Biofuels 7 07-20-2006 12:03 AM
Wish List.. Creating my own reality RebekahPom Classifieds | Buy, Sell, Swap 0 02-20-2005 07:56 PM
MTV's Reality Bar Crawl Steve Everything Else | General Skoolie Discussions 1 04-16-2004 09:19 PM
