Old 10-30-2016, 09:23 PM   #1
Rear axle gear ratios
It appears that for whatever reason most school buses are geared for around town driving and only some are geared for highway driving. Is there any way to tell which is which? I'm looking for a bus that can comfortable cruise at 60-65. What is involved in changing the gear ratios, is that a very expensive change to make and would parts to do that be readily available for an old bus?
Gazolba is offline   Reply With Quote
Old 10-30-2016, 11:23 PM   #2
Dapplecreek's Avatar
Rated Cap: 44 or 66? 11 rows
Others who know what they're talking about will chime in here with specifics. But I believe that seeing the label "Activity Bus" is a predictor for longer gearing. And sometimes basement storage.
Dapplecreek is offline   Reply With Quote
Old 10-31-2016, 10:13 AM   #3
Chassis: IH
I looked into regearing my bus which currently has a 5.38 ratio. If I do the "chunk" removal and installation myself, let a nearby shop do the actual gear replacement (as things have to be adjusted to certain specs), I can get it done for ~$850 or 900 + seals and fresh oil.
Old 10-31-2016, 01:05 PM   #4
Engine: TE 444
Rated Cap: 12
The easiest way is to fund out what type of rear axle you have and buy the whole center section with the gear ratio you want in it, cost me $650 when I got mine, but the spicer axle in mine was pretty common
Old 10-31-2016, 04:27 PM   #5
Jolly Roger's Avatar
Engine: Detroit 8.2
Check out differential wizard. They require some info upfront when you mail or talk to them but on there site they tell you what there going to ask and please have it ready to save all of you headaches. I called and talked to them and didn't have the info there web clearly states but they seemed to be good people even after dealing with me?
