Old 06-01-2009, 07:42 AM   #1
Year: 1985
Chassis: C60
Engine: 366 Chevy Gasser
Rear Caliper Siezed... HELP
Hey guys. Im new here. Just joined today. I have an 85 Chevy Bluebird schoolbus. We take it to the Pocono nascar races and the bus is called the Pocono Boozer... hence my name. I have a rear caliper that is siezed slightly. Im thinkin its a bad idea to just run it. I need to find the caliper and new brake hoses. NAPA saiys they can get the caliper if i measure this one... but they cany get the lines. Anyone got any ideas for where i can get parts for this?? THANK YOU ALL IN ADVANCE!!!!
PoconoBoozer is offline   Reply With Quote
Old 06-01-2009, 10:58 AM   #2
Re: Rear Caliper Siezed... HELP
previous experience tells me that if you need to replace 1 brakeline, it's probably time to replace all of the brakelines, you can either change all of them once or you can replace the weakest piece one at a time untill you replace them all. if you need steel lines, buy a roll of brakeline tubing from napa along with the double flare tools and fittings and make your own brakelines, they don't have to be identical copies, just make sure to tuck them in where they are protected from damage and secure them so that they don't vibrate/chafe against anything.
'91 Bluebird Disc Brake Caliper wheeler Mechanical and Drivetrains 16 09-13-2012 08:07 AM
brake pad and caliper replacement nyrockingchairs Conversion Tutorials and How-to's 1 06-28-2009 08:18 AM
Big Rig Rear End... NewSkewlHauler Conversion General Discussions 11 04-01-2009 03:25 PM
How to remove a Bendix Caliper off the bus? asnowsquall Everything Else | General Skoolie Discussions 2 10-02-2006 09:37 PM
Rear storage / Rear door ideas allanwcoty Conversion General Discussions 0 05-17-2005 11:52 AM
