Old 05-25-2005, 06:12 PM   #11
Eric von Kleist's Avatar
Year: 1985
Coachwork: ThomasBuilt
Rated Cap: 60
Very Nice!
Damn! That's really a good idea! I wish I had seen it a couple of days ago. I'll have to do that to my bus. I guess I can just put a bolt in the hole I drilled for the eye-bolt. That's an excellent idea. It looks very good.
How is lockplate attached on the inside? Sheet metal screws? Or are those bolts? What did you use for the black gasket/offset material under the lock?
Excellent idea.
Eric von Kleist is offline   Reply With Quote
Old 05-25-2005, 08:58 PM   #12
Kirbystud's Avatar
Year: 1987
Engine: 366 Gas
The lock is a dead bolt for a garage door. The screws are sheet metal screws. And the spacer I made out of 1/4 inch plastic. If I can help in any way let me know.
What happens on the trail stays on the trail
Kirbystud is offline   Reply With Quote
Old 05-28-2005, 07:21 AM   #13
Lea
Lea's Avatar
Can you spell it all out for me a little more. Where did you get your lock? What is the brand/type. Did it come with the sheet metal screws? If not what size do I need? Where did you get the plastic spacer? And then what?? Sorry for all the questions I am on a seriously low learning curve. All of this is new but I am so excited to get started. My Dad says I can use his shop and tools but I first need to get a lock on the bus to secure stuff when I am not using them. He also thinks I am incapable of learning because I have never done any of this before and you know I'm a girl. What he doesn't know is that I have all of you to help and I will prove him wrong. So not only am I on a mission to create a camper out of my new 1990 International Bus, but hopefully I will prove to my dad that my gender won't define my ability to do "mans" work.
-Lea
Not all who wander are lost.
Lea is offline   Reply With Quote
Old 05-29-2005, 08:30 AM   #14
Lea
Lea's Avatar
i did it. i found the garage lock. had to fabricate almost every part but now we are all locked up. i'll send pictures.
-lea
Old 05-29-2005, 09:52 AM   #15
Kirbystud's Avatar
Year: 1987
Engine: 366 Gas
Frist thing I want to say is ( You go girl) I can't get any of the females in my house to even help me..... Well I just sat down to the to send you the info you asked for and I see you all aready did it......Great......If there is anything I can do to heip you just let me know...
Old 05-31-2005, 11:31 AM   #16
dammitAndy's Avatar
Engine: 370
Rated Cap: 44
I love it!! Im gonna do that now. Much nicer than the gate latch and pad lock i am using. Ill have to fill the holes that i made with the gate latch but i dont care. Nice work!!!
'89 Ford 370-2V Wayne - Sold :(
http://www.dammitandy.com/bus
Plotting the next project now. Looking for a clean diesel pusher with low rust/miles. Identical plans with plumming and biodiesel added :)
dammitAndy is offline   Reply With Quote
Old 06-11-2005, 07:14 PM   #17
pangaia's Avatar
locked...er...lost the key though..
I just installed a sliding gate latch for my bus-master lock keeps it closed. Works fine for me as someone was messing with the backdoor last night. Just in time, no?
Anyway, I still have this rv lock set up that will eventually be the real door lock. Seems to be just the right thickness for the rear entrance but I've nothing to cut with so its on the back burner for now.
'Before you go out seeking revenge you must first dig two holes'--Chinese Proverb
Bright Blessings of the Mother upon you ;)
1990 International Ward Volunteer "Fantastic Voyage"
pangaia is offline   Reply With Quote
Old 07-15-2005, 02:23 PM   #18
Year: 1985
Rated Cap: 60
Lea's Thomas-built modification to the Kirbystud deadbolt
I copied Lea's Thomas-built modification to the Kirbystud garage door deadbolt lock on the back door. My back door had some internal metal that prevented me from mounting the lock as high as it really needed to be, but it works okay. It definitely stops the door's bolt from traveling, but repeated slamming of the handle might overwhelm it. Of course, anyone who wanted in that badly would probably just smash the lower window out. Maybe I should put expanded metal over the lower window...or all the windows...maybe I should have bought a prison bus!
It looks formidable from the outside, what with the padlock and the deadbolt cylinder in view.
...except for all that glass!
The whole fitting procedure is here http://www.skoolie.net/gallery2/Kirb...ltModification
Old 07-15-2005, 03:21 PM   #19
Steve's Avatar
Could either you or Lea please post a picture of the lock actually engaged. I am guessing you both notched the bolt on the bus door, but I don't see a picture that either of you have done so.
Oops, looks like what your lock does is prevent the bolt on the door from moving out.
Old 07-15-2005, 04:39 PM   #20
Year: 1985
Rated Cap: 60
You got it.
Yep, that's what it does. But your notion of the bolt engaging the door's bolt is interesting....
What if the deadbolt was mounted directly under the door lock assembly and engaged the bolt there? Hmmmmmm..... That's an idea. You'd have to do some major cutting on the door lock assembly and bolt, but you might be able to do it with a drill and some files or a sabersaw if you took teh assembly off of the door itself.
That would be a VERY strong lock.
Anti vandal lock rear door alarm gets stuck.. ON! missingTexas Conversion General Discussions 4 09-29-2014 06:37 PM
My plan to lock our air door bhays Conversion General Discussions 5 01-24-2012 06:29 PM
this is how I lock my door on the bus lornaschinske Conversion General Discussions 5 12-26-2010 02:20 PM
door lock needed keith Classifieds | Buy, Sell, Swap 0 01-04-2009 11:23 AM
Door lock ideas Branden Conversion General Discussions 12 05-02-2005 06:47 PM
