Old 07-10-2006, 04:25 PM   #1
Coma's Avatar
Year: 1981
Engine: 345
Rated Cap: 69
Rear Wheel Wobble
I'm kind of a new guy here, but not to skoolies. I'm starting my second project after melting a piston on the first one last year.
I have noticed a fairly bad vibration in the bus rolling down the highway. While having some friends follow me home, they said the rear wheels wobble with one side more than the other. Everything seems tight, but could they just need to be loosened up and re-alligned?? I find it hard to believe there is anything bent.
Thanks for any input............
Coma is offline   Reply With Quote
Old 07-10-2006, 04:48 PM   #2
Steve's Avatar
Do you have bias-ply tires? My tires used to get flat spots when I ran on those.
Old 07-10-2006, 04:53 PM   #3
Coma's Avatar
Year: 1981
Engine: 345
Rated Cap: 69
Not sure, I'll check. But it is definately a side to side wobble.
Old 07-10-2006, 09:14 PM   #4
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
On radials, I have experienced belt separation and shift that caused unbalanced / wobbly vibration. A tire shop was able to confirm the cause.
Griff is offline   Reply With Quote
Old 07-10-2006, 09:32 PM   #5
the_experience03's Avatar
Start with the easy stuff. Unless you have lug piloted wheels, chances are the wheels just need to be balanced on the vehicle. This is a matter of jacking it up, loosening the clamp bolts, and POUNDING everything in to make sure it is flush. Then you need to lightly tighten the clamps and slowly spin it. There are tools to check the runout, but the human eye works just fine as well. Slowly tighten and adjust them until the runout is right. The 18 year old kid that changed the tire on Havoc in Bloomer, Wisconsin earned himself a $15 tip for being so fast at changing the tire and balancing them better than they were on his first try.
Old 07-11-2006, 08:21 AM   #6
Coma's Avatar
Year: 1981
Engine: 345
Rated Cap: 69
Thanks Gents.
Wheel-well-less Bus? Beemobile Conversion General Discussions 9 08-11-2014 07:45 AM
Wheel Help? Please? lapeer20m Conversion General Discussions 0 10-05-2009 03:49 PM
Looking for 5th wheel rv trailer frank-id Classifieds | Buy, Sell, Swap 0 05-20-2009 12:07 AM
Rear storage / Rear door ideas allanwcoty Conversion General Discussions 0 05-17-2005 11:52 AM
